OBX 2 pulley set
vibe Freak
OBX 2 pulley set
Post by vibe Freak »
I just got these on today and WOW they are great. The little Vibe is really coming together nicely. I was supposed to leave it stock. Next will be the rear sway bar.
RFP1 17x8 , AFE Cold Air Intake, Helix Power Tower Plus, Eibach Sportline Springs with Tokico Blues, Progress sway bar, Alutec OEM Sized Lightened Crank Pulley full custom Magnaflow 2.5 header back exhaust and B&M tranny cooler E/S inserts Unichip.
CAN-AWD-VIBE
Re: OBX 2 pulley set (vibe Freak)
Post by CAN-AWD-VIBE »
Congrats!!!Those are the alt and crank pulleys right? Were they a PITA to install?leave it stock... good luck with that welcome to the addiction that is modifying
CAN-AWD-VIBE03 Neptune AWDInjen CAI, Hotchkis springs, custom magnaflow exhaust w/4" tip, tint, window deflectors, stubby antenna, 3pc Mr. Grille, foglight conversion mod, Grafxwerks front & steering wheels overlays, Injen oil cap, strut tower brace, P225/45R17 Michelin Pilot Sport A/S, 17" ADR Sokudos
vibe Freak
Re: OBX 2 pulley set (CAN-AWD-VIBE)
I had my mechanic do it for $45. He will be putting a new tensioner pulley and belt on for no charge on Monday.
CanadianTim
Post by CanadianTim »
Does the original belt still work? What improvements did you notice?Thanks
vibe Freak
Re: (CanadianTim)
Yes it still works, because the alternator pulley is bigger than stock. As fare as what it does way better throttle response. This is only for the 1zz motor.
CanadianTim
Good to hear it freed the motor up a bit. Do you have an Auto or 5 speed? Have you had any issues or heard of any issues with battery charging or AC operation? I suspect if the pulley ratios have that big an impact without any downside, that Toyota would be using them stock as these should increase fuel economy as well. I run nearly 100% highway so I've considered these since charging should not be an issue with my driving and the extra power is always a plus.
vibe Freak
Re: (CanadianTim)
I have a auto base vibe. I have had them on for a week now with no problems at all.
vibe Freak
Re: (vibe Freak)
Guys just make sure you change out the front main seal when you do the pulleys. Because you may get a slit oil leek if you don't. Ask me how I know
vibe Freak
Re: (vibe Freak)
New seal is in and the leek is all gone.
DopeVibeGT
Post by DopeVibeGT »
Leave it stock? Within the first month of having mine, I had the CAI and catback on. LOL They beg to be modded.
DopeVibeGT
Re: (vibe Freak)
Does this apply to the VVTL-i too?
vibe Freak
Re: (DopeVibeGT)
This only applies to the basic Vibe. This is only for the 1zz application.
1fstramand1slovibe
Re: (vibe Freak)
Post by 1fstramand1slovibe »
Where did you find those pulleys realy could use a good site. just got the ARE stage 2 intake and a vibrant strut bar on mine this weekend. already had a silverline canister and custom piping from the cat back with the resonators cut off.anyway i would really appreciate some help finding parts so far the only places ive found them is http://www.autopartswarehouse.com and http://www.performancecenter.com. any others out there
Raven
Re: (1fstramand1slovibe)
Post by Raven »
http://www.neverenoughauto.com...d=899 He is an excellent supplier. A Genvibe member too.
1fstramand1slovibe
Re: (Sunny)
thanks great looking sites.
northvibe
Post by northvibe »
i read on another site...9thgencorolla i think that they have new aluminum T70xxx or something which is lighter and stronger than the current T60xxx made ones. just a fyi
1fstramand1slovibe
Re: (northvibe)
where did you find those obx pulleys?
vibe Freak
I looked under celica pulleys on eBay. They are $95.00 plus 15 for shipping. i am running the stock size belt because the alternator pulley is bigger. They work great, but I would change the seal when you do the pulleys.
Raven
Re: (vibe Freak)
Post by Raven »
What's up with the seal? Does it get damaged during the removal of the stock pulley and need replacing?
1fstramand1slovibe
Re: (Sunny)
yeah im kinda wondering about that myself.
scherry2
Re: (vibe Freak)
Post by scherry2 »
Quote, originally posted by vibe Freak » i am running the stock size belt because the alternator pulley is bigger. is there a certain belt you need if only changing the crank pulley or will the tensioner take up the slack?
vibe Freak
Re: (scherry2)
The seal is so it will not leek. The old seal will be worn so a new one will be a nice tight fit. I had a little leek I had the seal replaced and no more leek. As fare as the belt I am really not shore.
