I get to have my rotors turned on the car for free. woohoo
Posted: Tue Oct 03, 2006 3:40 am
by 4X4CHICHI
I just machined some brake caliper adapters for my buddy's 300Z twin turbo. He put these huge discs on his car and I made the adapters. So in return he is going to let me come to his shop and he is going to turn my rotors on the car for free. I hear this is the best way to have them turned. Has anyone else heard of this?
Re: I get to have my rotors turned on the car for free. woohoo (4X4CHICHI)
Posted: Tue Oct 03, 2006 3:43 am
by GrayFox
Quote, originally posted by 4X4CHICHI » I hear this is the best way to have them turned. Has anyone else heard of this?As in get your buddy to do it for free? yeah that's seems like a good way to me! j/kI'm not really sure what you're asking since you don't describe what method he's using. I didn't know there was more than one way of turning rotors
Re: I get to have my rotors turned on the car for free. woohoo (ANO_Vibe)
Posted: Tue Oct 03, 2006 3:54 am
by 4X4CHICHI
He said you leave them on the car and the machine attaches to your hub. I guess.Normally, I have them turned on a lathe.
Posted: Tue Oct 03, 2006 4:58 am
by SeattleJeremy
Sounds like a weird way to do it. I've only ever seen brake shops use a lathe. But hey if it's free, and your brakes need it then heck yea!
Re: (Jeremy96gase)
Posted: Tue Oct 03, 2006 5:05 am
by 4X4CHICHI
I guess it's the only way to get them totally true to your car.
Re: (4X4CHICHI)
Posted: Tue Oct 03, 2006 8:41 am
by keithvibe
Your buddy is correct. You are better off having the rotor turned while it's on the car. It uses the wheel berings for balence. not a balenced lath. you will get a better turn of the rotor being it's "customized" to your car.
Re: (keithvibe)
Posted: Tue Oct 03, 2006 1:48 pm
by 4X4CHICHI
And it's free
Re: (4X4CHICHI)
Posted: Wed Oct 04, 2006 1:14 am
by CAN-AWD-VIBE
more importantly it works well.most of the dealers are going to this style of on car lathe. It is just plain faster and easier to setup.plus you can still charge the same labor but save time = more profits.CAN-AWD-VIBE
Re: (CAN-AWD-VIBE)
Posted: Wed Oct 04, 2006 1:25 am
by 4X4CHICHI
He's going to try to get me a set of tires from a 350Z also. sweet.
Re: (4X4CHICHI)
Posted: Wed Oct 04, 2006 3:42 am
by CAN-AWD-VIBE
those tires are no good to you though... stock on a lower end 350 is 225/45R18 in front and 245/45R18 for the rears... thats not going to a agree with you little vibe as well as it might look.thats a 4.4% difference in front and 7.2% difference in the back. the only good that will do for you is fill in whats left of your fender gap.CAN-AWD-VIBE
Re: (CAN-AWD-VIBE)
Posted: Thu Oct 05, 2006 10:34 am
by 4X4CHICHI
HMMM. He seemed to think that the tires were 17"ers
Re: (4X4CHICHI)
Posted: Thu Oct 05, 2006 11:00 am
by CAN-AWD-VIBE
maybe older model? I dunno but Im sure the 350 has 18's stock
Re: (CAN-AWD-VIBE)
Posted: Thu Oct 05, 2006 8:56 pm
by 2002sportside
A 2003 350Z Base model had 225/50 up front and 235/50 in the back.
Re: (2002sportside)
Posted: Fri Oct 06, 2006 1:54 am
by 4X4CHICHI
That doesn't tell us the rim size.
Re: (4X4CHICHI)
Posted: Fri Oct 06, 2006 4:59 am
by 2002sportside
Sorry, they were 17s. I thought that was implied since it was answering CAN-AWD-VIBE's post about the 350 not having 17s...
Re: (2002sportside)
Posted: Fri Oct 06, 2006 5:08 am
by 4X4CHICHI
If that is the case, then the fronts would only be less than an inch on the diameter. That's not hateful.
Re: (4X4CHICHI)
Posted: Fri Oct 06, 2006 5:10 am
by 4X4CHICHI
the rears would be a little more than 1.25 on the diameter and only about 3/8 wider, hmmmmm
Re: (4X4CHICHI)
Posted: Fri Oct 06, 2006 10:27 am
by CAN-AWD-VIBE
better... but unless its a great deal its not worth it to me. IMHOwith the AWD- im not willing to mess with my tire size too much, especially when i sc.
