Household plug
Posted: Wed Aug 23, 2006 4:55 am
by tomspec
What is your FAVORITE use for the household plug in the Vibe?
Re: Household plug (tomspec)
Posted: Wed Aug 23, 2006 5:22 am
I've used mine for a laptop, razor, an AA batteriy charger, a soldering iron (while working on the car )During some protracted power outages, I've also run an extension cord into the house to power my woodstove fan, a TV, and also my cable modem and wireless router (but not all at the same time)Hard to fit all that into a single poll voteThere's another thread I remembered, SAYSF, but it's not a poll : http://forums.genvibe.com/zerothread?id=193
Re: Household plug (joatmon)
Posted: Wed Aug 23, 2006 5:51 am
by zionzr2
100 watts goes a long way!!!
Posted: Wed Aug 23, 2006 6:37 am
by GMJAP
Quote, originally posted by tomspec »What do you use your household plug for?This poll is problematic because each member only gets 1 vote, but may use the 110 outlet for multiple things.
Re: Household plug (GMJAP)
Posted: Wed Aug 23, 2006 10:00 am
by binary
Quote, originally posted by GMJAP »This poll is problematic because each member only gets 1 vote, but may use the 110 outlet for multiple things."What is your FAVORITE use for the household plug in the Vibe?"
Re: Household plug (binary)
Posted: Wed Aug 23, 2006 10:01 pm
by tomspec
That's my fault. I edited and changed it from "what do you use it for" to "what is your favorite use."
Re: Household plug
Posted: Thu Aug 24, 2006 12:04 am
by Mase
One time we had church service outside in a park. When I got there I saw a PA system and amplifier plugged into a 100' extension cord running into a Vibe!
Posted: Thu Aug 24, 2006 2:41 pm
by whatthefunk41
i also use it to charge my fone cuz im to lazy to buy a car charger
Posted: Thu Aug 24, 2006 3:21 pm
by AKLGT
used it for the laptop when we drove the vibe up from Ontario.
Posted: Fri Aug 25, 2006 9:37 am
by vibebob
how do y'all plug laptop's into the outlet ? my work has one, but the plug on the AC adapter is the three prong type.
Posted: Fri Aug 25, 2006 4:11 pm
by kostby
Use an old-school gray 3-prong to two-blade (polarized) adapter. Works just fine! I'd post a pic but the adapter is out in the car and it's 3 AM!
Re: (kostby)
Posted: Thu Sep 14, 2006 9:52 pm
by BuzzDog
I use my laptop with a GPS sensor and mapping/tracking software when I'm working on the road; I fold the front seat forward and secure the laptop to the seatback with a ratchet strap. Like the previous poster, I use an old-school three prong adapter. Saves me from having to worry about my battery, plus I have my laptop display set up to default to full brightness when it's plugged in...MUCH better for daytime use.
Posted: Sun Sep 17, 2006 6:25 am
by Emerica13
Quote, originally posted by joatmon »I've used mine for a laptop, razor, an AA batteriy charger, a soldering iron (while working on the car )During some protracted power outages, I've also run an extension cord into the house to power my woodstove fan, a TV, and also my cable modem and wireless router (but not all at the same time)Hard to fit all that into a single poll voteThere's another thread I remembered, SAYSF, but it's not a poll : http://forums.genvibe.com/zerothread?id=193How can you solder wiring on your car with it? If you're soldering wiring, the battery should be disconnected, but even if you dont disconnect it, it certainly shouldnt be powering anything while you're messing with the wiring. just wonderin
Re: Household plug (Emerica13)
Posted: Sun Sep 17, 2006 8:00 am
by BuzzDog
He may have been soldering something other than the wiring...or perhaps soldering a ground connection on something while the hot lead was disconnected. May be a stretch, but it could be so...
Posted: Sun Sep 17, 2006 8:28 am
by northvibe
the salemans at the ponti dealer told me i could use it for my blow dryer...i thought he was retarded and just looked at him like a idiot. a blow dryer would 99% likely blow or trip the fuse....uh salesman oh yea...WTH do i need a blow dryer for!
Posted: Sun Sep 17, 2006 9:09 am
by prtlnd03gt
i use a glade plug in
Re: (northvibe)
Posted: Sun Sep 17, 2006 10:43 am
by BuzzDog
Quote, originally posted by northvibe »a blow dryer would 99% likely blow or trip the fuse...Well, I shave my head, so the salesman knew better than to mention that use to me. But I'll guarantee that using one in the recepticle will trip the built-in circuit breaker (which automatically resets itself). The recepticle is rated at one amp...a 1200-watt blow dryer draws about 10 amps (1200 watts divided by 120 volts equals 10 amps).
Posted: Sun Sep 24, 2006 9:17 am
by prtlnd03gt
anybody know if it would be possible to plug in a powered sub for a computer...
Re: (prtlnd03gt)
Posted: Sun Sep 24, 2006 1:12 pm
by ColonelPanic
If it doesn't exceed 100w, youbetcha
Re: (kostby)
Posted: Fri Oct 06, 2006 5:12 am
Quote, originally posted by kostby »Use an old-school gray 3-prong to two-blade (polarized) adapter. Works just fine! I'd post a pic but the adapter is out in the car and it's 3 AM!Here ya go kostby:If anyone's wondering, the outlet is a nice way to power a dremel too!
Re: (ragingfish)
Posted: Fri Oct 06, 2006 7:17 am
by NascarXprt
i just use it for when i need to charge my cell phone.
Posted: Sat Nov 18, 2006 4:31 pm
by Mugen
Hmm, glade plugin. That's really a great idea, always have my car smelling fresh!
Re: (Mugen)
Posted: Mon Nov 20, 2006 7:28 am
by chemrebel
i just used the plug today for the first time since i've had my vibe.i have a 30 minute commute to work and we were having a thanksgiving potluck. so i whipped up some green bean casserole in my crock-pot, plugged my crock-pot into the plug and away i went.
