AC temp at vent
Posted: Wed Aug 16, 2006 4:51 am
by Digger
my temp was 50 Deg. at the center vent with fan on high and Recirc. on. The freon tested at full range. The temp should be 40 Deg., so I went to advanced auto and put it in. Now the temp is 38 Deg. If you do this make sure you get freon with out leak seal or oil.After adding the can of freon the freon still tested in the full range.
Posted: Wed Aug 16, 2006 5:21 am
by northvibe
you just got a recharge kit? dang 38 sounds good...hmmmm i like having a cold car, specially when driving girls around...hahhah
Re: (northvibe)
Posted: Wed Aug 16, 2006 5:47 am
by Mrizzle05
*slaps wrist* bad northvibe!!!
Re: (northvibe)
Posted: Wed Aug 16, 2006 10:53 am
by binary
Quote, originally posted by northvibe »you just got a recharge kit? dang 38 sounds good...hmmmm i like having a cold car, specially when driving girls around...hahhah zing... That's strange - how were you testing it? Is it by pressure? (AC newbie...)
Posted: Wed Aug 16, 2006 11:15 am
by northvibe
for temp with AC , i think youd just have a thermalstat or a laser one and take it at the vent.
Re: AC temp at vent (Digger)
Posted: Wed Aug 16, 2006 11:55 am
by VibeoFive
If you really love your Vibe, consider adding refrigerant only a temporary measure. That system only has a 1.54 lb capacity, so if you in fact installed one pound (16ozs.), you had a very low charge. An evac. & recharge at a repair facility (with leak tracer or dye) would go alot further in properly maintaining your compressor (and it would only set you back about $90!
Re: AC temp at vent (VibeoFive)
Posted: Thu Aug 17, 2006 11:37 am
by Digger
Yep I put one can useing a kit I got when I fixed my 98 villager AC. Just make sure the freon does not have any oil or Die in it. I used a preasure gage to check the fill. The system has a min and max just like all fluid systems. I would say gm put the min amount in. After adding the can of freon my system preasure is still in the save range.
