Changing my spark plugs
Posted: Tue Aug 15, 2006 10:52 am
by erabralop
How the heck do you get that plastic deck off?The two bolts are a snap, but those factory clips I just can't figure out.
Re: Changing my spark plugs (erabralop)
Posted: Tue Aug 15, 2006 10:58 am
by BlueCrush
You have to get a flathead screwdriver and pop them out. You will be able to put them back in when done. They will only last a few times popping then in and out before they are trashed. Then you can get new ones from Toyota or just leave them out like I did. Good Luck!
Posted: Tue Aug 15, 2006 12:29 pm
by erabralop
Sweet deal, managed to only break one.
Posted: Thu Aug 17, 2006 1:04 am
by ToolGuy
I lost one of those plastic fasteners, somewhere in the engine the second time I had it off... I have since replaced both with bolts because the holes are threaded!
Re: Changing my spark plugs (MiVibe-ToolGuy)
Posted: Thu Aug 17, 2006 2:25 am
by JohnC
Quote, originally posted by MiVibe-ToolGuy »I have since replaced both with bolts because the holes are threaded! Good tip, thanks.Does the cover actually do anything, or is just for looks?
Re: Changing my spark plugs (JohnC)
Posted: Thu Aug 17, 2006 2:27 am
by ToolGuy
Kind of mostly for looks but I suppose it keep debris from sitting on top of the engine. It does have a pad under it too possibly for noise...
Posted: Thu Aug 17, 2006 11:21 am
by binary
Solid lifter noise reduction...tap tap tap tap tap tap tap tap tap ...
