Can you wire a sub+amp with the M&T System??
Posted: Mon Aug 14, 2006 3:00 pm
by Markt2717
basically you know what im asking just have no idea how to do it. ive got a 2006 vibe with M&T. is there anything i can do as far as MORE Bass?? THANKS!!
Re: Can you wire a sub+amp with the M&T System?? (Markt2717)
Posted: Mon Aug 14, 2006 9:42 pm
by binary
Funny you should ask - I'm planning the same thing.What I plan on doing is re-routing my sub's audio lines to my amp's speaker line input (or you can use an adapter that will change a line input to RCA output).I plan on using some relays to allow me to switch between the two... but so far, I'm still working on the planning stages.
Posted: Mon Aug 14, 2006 9:45 pm
by JustinVGT
Yes you can. If your amp has high level inputs, you just have to tap into the high level outputs from the amp under the seat. That is what I did when I connected my Bazooka with a built-in amp. I don't recall which exact wires I tapped into since it was a while back. Here is my old post from my install:
http://forums.genvibe.com/zerothread?id=18348 Here is a thread that may be helpful and has a link to the wiring diagram:
http://forums.genvibe.com/zerothread?id=17810 I'm not sure if they changed the amp in the 06 model, might need to search on that.
