Can't access chat.
Posted: Tue Aug 01, 2006 11:34 am
by GMJAP
I can't get into the chat room, either from my machine at work or home. I get the following unhelpful error. Any ideas what might be the problem?thanks
Re: Can't access chat. (GMJAP)
Posted: Mon Aug 07, 2006 3:40 am
by GMJAP
*bump* help!
Posted: Mon Aug 07, 2006 3:43 am
by BlueCrush
I was able to log on fine. Might be your settings. (whatever those are)
Re: Can't access chat. (BlueCrush)
Posted: Mon Aug 07, 2006 5:08 am
by redlava
The only way I can get into the chat is if I use Explorer. Firefox won't work for me at all. So I guess you could try that.
Posted: Mon Aug 07, 2006 5:13 am
by BlueCrush
I'm using Opera 9 by the way with no problems.
Re: Can't access chat. (redlava)
Posted: Mon Aug 07, 2006 5:21 am
by GMJAP
Thanks for the tips.I'm using Explorer, and I used to be able to login no problems. Now I can't from either work or home.Could this be a firewall thing? ADMINS- does it use any different ports?
Posted: Mon Aug 07, 2006 5:26 am
by millster
The most important thing to note here is that this is NOT actually hosted as a part of Genvibe. We really have no control over it.Standard HTTP port though. It's just a Java applet hosted on a regular website.My suggestion would be to try removing/reloading Java VM on your computer. Uninstall as you would any application and then download it from:
http://www.java.com/en/download/manual.jsp
Re: Can't access chat. (millster)
Posted: Mon Aug 07, 2006 11:10 am
by GMJAP
OK, it definitely is a firewall issue. I put the firewall here at home down to low, and could connect no problem.There must be something different from the standard HTTP port....
Posted: Mon Aug 07, 2006 6:10 pm
looks like loading the applet uses some random port, but logging in and sending lines seems to consistently use TCP port 8002
Re: Can't access chat. (joatmon)
Posted: Tue Aug 08, 2006 11:23 am
by GMJAP
Quote, originally posted by joatmon »looks like loading the applet uses some random port, but logging in and sending lines seems to consistently use TCP port 8002THANK YOU! Just needed to change my firewall script to allow port 8002.
Posted: Tue Aug 08, 2006 11:37 am
by Vibe_dude
Where can u log into this chat room....i dont see a link on the site anywere.
Re: Can't access chat. (Vibe_dude)
Posted: Tue Aug 08, 2006 11:39 am
by NSimkins
Quote, originally posted by Vibe_dude »Where can u log into this chat room....i dont see a link on the site anywere.
http://forums.genvibe.com/zerothread?id=21783Link is in first post of the thread linked above.
Re: Can't access chat. (NSimkins)
Posted: Tue Aug 08, 2006 11:44 am
by Vibe_dude
Cool......wow did not see that at all.......thx's
