Place to Ground Amp?
Posted: Thu Jul 27, 2006 4:13 am
by Travg73
Hello, I need to know a good place to ground my amp ('03 Vibe). Can anyone help?
Re: Place to Ground Amp? (Travg73)
Posted: Thu Jul 27, 2006 4:15 am
by Mrizzle05
is your subs and amp in the back hatch area? wheres you location gonna be. i just grounded mine to one bottom of the bolts under the plastic access pieces where the spare tire is.sorry if that seems confusing. ill try and find a pic to show you.
Posted: Thu Jul 27, 2006 4:17 am
by AKLGT
yep, super easy if it's in the rear hatch.
Re: Place to Ground Amp? (Mrizzle05)
Posted: Thu Jul 27, 2006 4:31 am
by Travg73
thanks for the reply, the box is in the hatch area. How did you get the wire under there?
Posted: Thu Jul 27, 2006 10:41 am
by AKLGT
the plastic parts unbolt. also, you can take that top off right behind the rear seats. it's another area to put more things.
Re: (trdvibe)
Posted: Thu Jul 27, 2006 11:57 am
by Mrizzle05
there is a pic i uploaded here... it shows that rectangular cover up with the ground wire for my capacitor which is for the amp...
Re: (Mrizzle05)
Posted: Thu Jul 27, 2006 1:34 pm
by damronjr
Make sure you grind down the metal/paint to get a good ground on both sides of whatever you are putting it between.
