Rear Brake Adjustment
Posted: Tue Jul 04, 2006 1:53 am
by zionzr2
What is the proceedure for doing a rear brake adjustment on our vibes....Wanna do it myself rather than paying someone $30 and not putting my wheels back on correctly...Plus save myself 30 bucks
Re: Rear Brake Adjustment (zionzr2)
Posted: Sat Jul 08, 2006 6:48 am
by zionzr2
^bump^
Posted: Sat Jul 08, 2006 6:52 am
by JohnC
The daily use of the emergency (hand) brake should keep it adjusted. The drum type can be manually adjusted, and I do not know about rear disc on this car (mine is the base model).
Re: Rear Brake Adjustment (JohnC)
Posted: Sat Jul 08, 2006 8:41 am
by zionzr2
mine is drums in the rear...also is there a way to adjust the feel of the pedal....it always seemed a tad mushy as compared to other vehicles i have had.i like a firm almost instant grab in my brake pedal.
Posted: Sat Jul 08, 2006 8:46 am
by Raven
If they are really mushy, you could try bleeding them, otherwise there is no adjustment for pedal feel.
Re: Rear Brake Adjustment (Sunny)
Posted: Sat Jul 08, 2006 10:44 am
by JohnC
Bleeding them usually cures the mush, if that doesn't work you could replace the rubber brake hoses with stainless flex hose this has greatly improved some of my past vehicles. Before doing this I would check out the rest of the system.
