				Drivers Door Switch Plate -- How is it attached?
				Posted: Wed Jun 14, 2006 10:08 am
				by geezer
				The Window switches and Door Lock Buttons push down into the door when I push on them.Does anyone know how the panel the switches are mounted into  is attached?   Is it glued or are there clips holding it.  Will I break something else by prying it up or should I remove the entire interior door panel?
				Re: Drivers Door Switch Plate -- How is it attached? (geezer)
				Posted: Wed Jun 14, 2006 10:17 am
				by GMJAP
				The silver trim and the module underneath that has all the buttons should be attached together.You can remove the silver trim by prying it up on the upper end, then pulling it up and out.  I'm not sure if the switch block clips into it or screws into it, but once you get the trim up you should be able to see.
				Re: Drivers Door Switch Plate -- How is it attached? (GMJAP)
				Posted: Wed Jun 14, 2006 12:52 pm
				by jeffgtx
				if memory serves, its a big clip.careful how you remove it, once i did mine, it never clipped back quite the same.
				Posted: Wed Jun 14, 2006 6:22 pm
				by scherry2
				remove the door panel first!! then look at the back side. never pry up on things unless your sure thats how they come off. just a bit of freindly advice from a former auto repairman
				Re: Drivers Door Switch Plate -- How is it attached? (scherry2)
				Posted: Wed Jun 14, 2006 10:44 pm
				by GrayFox
				Definatly take the door panel off first. You should see how everything's attached.
				Posted: Wed Jun 14, 2006 11:53 pm
				by GMJAP
				Quote, originally posted by scherry2 »remove the door panel first!! then look at the back side. never pry up on things unless your sure thats how they come off. just a bit of freindly advice from a former auto repairmanYou don't need to do this.  Just pry up on the top of the silver trim.  I've removed mine before; this is how it's done.  It's described as such in the service manual.See attachment:
				Posted: Thu Jun 15, 2006 1:15 am
				by scherry2
				Quote, originally posted by GMJAP »I've removed mine before; this is how it's done.  It's described as such in the service manual.I wish you would have said that in your first post, I wouldn't have advised this: Quote, originally posted by scherry2 » never pry up on things unless your sure thats how they come off.
				Posted: Thu Jun 15, 2006 1:41 am
				by damronjr
				Quote, originally posted by scherry2 »remove the door panel first!! then look at the back side. never pry up on things unless your sure thats how they come off. just a bit of freindly advice from a former auto repairmanYou're still right, it just happens to be how it comes off in this case!
