Engine swap
Posted: Fri Jun 09, 2006 1:47 am
by TheShadow
Re: Engine swap (TheShadow)
Posted: Fri Jun 09, 2006 1:53 am
by BlueCrush
HAHAHAHA! It might be a tight fit, but do it! You'll probably need to upgrade your tranny though.
Posted: Fri Jun 09, 2006 2:26 am
by damronjr
Turbo that *****!
Posted: Fri Jun 09, 2006 2:36 am
by SeattleJeremy
Not excatly the High Revving type of engine you might be use to. But definaly more powerful!Turbo it? This is the largest one I can find, I don't think it'll do much.
Re: (Jeremy96gase)
Posted: Fri Jun 09, 2006 2:42 am
by damronjr
Quote, originally posted by Jeremy96gase »Not excatly the High Revving type of engine you might be use to. But definaly more powerful!Turbo it? This is the largest one I can find, I don't think it'll do much. Yeah, guess you'll just have to look around for a CAI and exhaust that will open 'er up a little!
Posted: Sat Jun 17, 2006 3:22 pm
by Lancer
How much nitrous (or propane) do yo think you'd need? A 2 hundred thousand shot?Think Bulley Dog has some upgrades for it?
Re: Engine swap (Lancer)
Posted: Sat Jun 17, 2006 3:36 pm
by tcam
lol. Just imagine trying to change the oil in that thing.
Re: Engine swap (tcam)
Posted: Mon Jun 19, 2006 1:48 am
by NascarXprt
well with that engine you dont need to buy lowering springs
Re: Engine swap (NascarXprt)
Posted: Wed Jun 21, 2006 3:14 am
by 1oldbanjo
These engines are already turbocharged - they are two stoke diesels and must be turbocharged or supercharged (sometimes two stoke diesels will get both). When the piston approaches the bottom of the cylinder the exhaust valve opens and the piston uncovers ports in the bottom of the cylinder that allow air to enter the cylinder at the bottom and push the burned fuel/air mixture out the exhaust valve at the top of the cylinder. The incoming air must be pressurized to be able to force the exhaust out the top of the cylinder. In the diagram for the engine you can see the snail shaped outline of the turbocharger on the right side of the engine - and I am sure that it is really BIG! It is possible that each cylinder could have it's own turbocharger - or that several cylinders could share a turbocharger.Dave
