Dead as a doornail
Posted: Mon May 15, 2006 10:43 pm
by Burstgoof
Just looking for some generic advice....This morning, I went out to my '04 Vibe but when I used the keyless entry, nothing happened. So, I was expecting a battery problem. When I tried to start it up, I got dash instruments (Check Engine, Oil, and Battery lights), and a buzzing sound (which I assume is the starter relay kicking in), but nothing else... no turn over, no sound from the starter or anything else. My first thought is that the battery is completely dead. When I turn to ACC, I get no power windows, no radio, etc. However, after jumping the battery for about 10 minutes, I still have nothing... and that's what has me worried.I'm thinking of trying a new battery in it tonight, but I have a suspicion that I might have bigger problems. Does anyone have more experience with starting issues? After charging the battery for about 10 minutes, shouldn't I have at least heard the starter trying to turn over?Thanks for any help or suggestions.
Re: Dead as a doornail (Burstgoof)
Posted: Mon May 15, 2006 11:25 pm
by BlueCrush
I'd say battery cannot hold a charge anymore. Time for a new one.
Re: Dead as a doornail (BlueCrush)
Posted: Mon May 15, 2006 11:27 pm
by Burstgoof
Yep, I think so too. I'm pretty sure that it's the original factory battery... so it would be about that time now. (it's an '04, so late '03 - '06).Thanks for the input.I'll swap out the battery tonight.
Posted: Mon May 15, 2006 11:32 pm
by Raven
If it's a manual, try bump starting it, if it's in a good location. Remove the battery and put it on a charger for a few hours or bring it somewhere to be tested. Is it the original tiny 350 CCA battery. They may replace it for free if you are still under warranty, they upgraded them to 550CCA for free for anyone living in a cold area such as Albany. There is a TSB about it.(technical service bulletin)
Posted: Tue May 16, 2006 1:36 am
by damronjr
Quote, originally posted by Burstgoof »Yep, I think so too. I'm pretty sure that it's the original factory battery... so it would be about that time now. (it's an '04, so late '03 - '06).Thanks for the input.I'll swap out the battery tonight.Sounds like it, but let us know how it goes.
Posted: Tue May 16, 2006 2:59 am
by Digger
I would think it would start if you had bosters hooked up to it from another car. If a new battery does not work check the main under the hood fuse box.
Posted: Tue May 16, 2006 1:10 pm
by Baltovibe
Similar problem at
http://forums.genvibe.com/zerothread?id=22559However, the original poster did not leave a reply of the outcome / solution.
Posted: Tue May 16, 2006 8:13 pm
by Burstgoof
Just like we all thought, last night I replaced the battery with a brand new one (MAXX 35DN from Wal Mart = $62, 875 CCA) and all is well.The battery that was in there was the original.Thanks for all your help everyone.
Re: (Burstgoof)
Posted: Wed May 17, 2006 12:10 am
by scherry2
Quote, originally posted by Burstgoof »(MAXX 35DN from Wal Mart = $62, 875 CCA) that is an expensive battery. I replaced mine last year in my 03.
Re: (Burstgoof)
Posted: Wed May 17, 2006 3:07 am
by damronjr
Good to hear that's all it was!
Re: (Burstgoof)
Posted: Wed May 17, 2006 5:10 am
by NascarXprt
glad to hear that its up and running again.
Posted: Wed May 17, 2006 5:33 am
by drunkenmaxx
my 03 (purchased april 02) still has the original little pooper batter in it and is working fine! wonder when it will konk out on me.
Re: Dead as a doornail (drunkenvibe)
Posted: Wed May 17, 2006 7:23 am
by Vibe_dude
Quote, originally posted by drunkenvibe »my 03 (purchased april 02) still has the original little pooper batter in it and is working fine! wonder when it will konk out on me.mine is still oem.......its a 03........car # 449 of the line if i remeber right....so i guess some are good others were crap.
