rca speaker connections ...... help
Posted: Tue May 09, 2006 10:47 am
by P-Fernandez
i need hep connecting an amps rca connrctors to the stereo, etci want soethng easy....... plz helpalso tel me what color are the wires, + / -
Posted: Wed May 10, 2006 5:52 am
by Jahntassa
If you're trying to connect RCA cables to a stereo, there isn't much we can do to help you. RCA is RCA.Are you trying to connect an aftermarket amplifier to the stock radio, and also, the stock speakers?
Posted: Wed May 10, 2006 10:07 am
by P-Fernandez
i already have the amp connected to power, ground, speakers. the amps input is rca. i have some speakers in the trunk. i just need to wire the amp to an imput ( stock HU )
Posted: Wed May 10, 2006 12:12 pm
by Jahntassa
You need one of these to wire into the speaker outputs of the headunit in order to connect the RCAshttp://
www.circuitcity.com/ssm...il.do
Posted: Thu May 11, 2006 12:05 pm
by P-Fernandez
would this workhttp://scosche.com/scosche_car...=SLC4 ????
Posted: Thu May 11, 2006 10:20 pm
by Jahntassa
Yes
Posted: Sun May 14, 2006 9:27 am
by josholiver1
How does that connect to the wires in back? It says no cutting or splicing wires...
Re: (josholiver1)
Posted: Sun May 14, 2006 9:31 am
by Jahntassa
Quote, originally posted by josholiver1 »How does that connect to the wires in back? It says no cutting or splicing wires...What says no cutting or splicing wires? You'll have to cut or splice something in order to make these devices work.
Posted: Sun May 14, 2006 9:36 am
by josholiver1
Tsunami RCA Line Output Converter (FLLOC600) Line output converter: Add an amplifier to your factory sound system with ease by converting your existing speaker wires into RCA outputs, so you can connect an amp to your factory radio without cutting or splicing any wires. ????? Got me...mabie i read it wrong..
Posted: Sun May 14, 2006 12:23 pm
by Jahntassa
Don't know what the description is trying to say, but the Tsunami box is bare wire on one end and RCA jacks on the other.
Posted: Mon May 15, 2006 7:11 am
by josholiver1
Ok..so what wire does that hook up to in back..corrisponding colors?
Posted: Mon May 15, 2006 8:41 am
by Jahntassa
http://forums.genvibe.com/zero...o.gifYou want the wiring between 'Front Audio Output' and 'Front Audio Input'
