Drove Vibe for first time, impression-handling/steering is fair-suggestions to improve?
Posted: Sat May 06, 2006 4:06 pm
by lexicon
Drove the Stock automatic for the first time. Impression is that the steering responsiveness is somewhat slow. I am used to a Supra, what do you suggest to do to give you that improved tossability and responsiveness to the steering wheel?The only improvements I have read about are sway bars and springs.Will these make the car more nimble in terms of being able to turn wheel and get the car to respond more quickly?
Re: Drove Vibe for first time, impression-handling/steering is fair-suggetions to improve? (lexicon)
Posted: Sat May 06, 2006 4:30 pm
by NascarXprt
also a strut tower brace will most probaly help it. but yes springs and swaybars will help with the steering response.
Posted: Sat May 06, 2006 5:42 pm
by ColonelPanic
Sounds like what you really need is some steering gear with a quicker response - but I highly doubt a higher performance rack exists for this application. Mine drives crazy now, the rack is pretty screwed up - it's all over the place in the blink of an eye, I guess if you bought a Vibe we could trade rack and pinions. j/kYou can always go with a different tire, that could make all the difference in handling and steering response as many here have found.
Posted: Sun May 07, 2006 2:02 am
by NSimkins
Quote, originally posted by lexicon »The only improvements I have read about are sway bars and springs.Springs and sway bars will make the most improvement in steering response as well as high-performance tires.
Posted: Sun May 07, 2006 12:30 pm
by northvibe
i concur,good tires, strut tower bar, front and rear sway bars and new springs or coil overs, would help it out.
Posted: Sun May 07, 2006 1:09 pm
by AKLGT
1. springs2. strut bar3. sway bars
Re: (trdvibe)
Posted: Mon May 08, 2006 1:34 am
by ballrub
4. Bigger wheels / lower profile performance tires!
Re: Drove Vibe for first time, impression-handling/steering is fair-sugge ... (lexicon)
Posted: Mon May 08, 2006 3:02 am
Quote, originally posted by lexicon »I am used to a Supra, what do you suggest to do to give you that improved tossability and responsiveness to the steering wheel?Coming from a supra, maybe some amount of lowered expectations are required. I came to the Vibe from a land yacht, so the nimbleness and responsiveness of the Vibe steering were much better than what I had before.
