05 Accessory Drive Belt R/R
Posted: Thu Apr 27, 2006 9:51 am
by Mach2
35,400 miles on the 05 Vibe and was wondering about the scheduled R/R mileage for the Alternator/Air Cond Accessory Belt. I was looking at it and didn't see the tensioner pulley where you could loosen and remove the belt by loosening the pulley. Is R/R'ing this belt a home done deal or is it a Dealer only job?
Re: 05 Accessory Drive Belt R/R (Mach2)
Posted: Thu Apr 27, 2006 10:19 am
I did mine at 100K miles. Helps to have small hands, which I don't.there's some info at
http://forums.genvibe.com/zerothread?id=16476
Re: 05 Accessory Drive Belt R/R (joatmon)
Posted: Thu Apr 27, 2006 11:02 am
by Mach2
Thanks joatmon, the pic's will work.
Posted: Fri Apr 28, 2006 7:23 am
by Lancer
I've swapped mine about 4 times trying to get the right configuration with the aftermarket pulleys and s/c.The best way to do it is to remove the right frnt tire and splash shield in the wheel well. You'll be able to reach all the pulleys then.
Re: 05 Accessory Drive Belt R/R (Lancer)
Posted: Fri Apr 28, 2006 10:40 am
by Mach2
Thanks too for the tips Lancer. I have a stock Vibe, not a GT and am thinking about preventative maintenance.
Posted: Fri Apr 28, 2006 9:17 pm
by Vibe_dude
did mine 3 weeks ago,had 98,000kms, on stock belt......went in under the hood........2 ppl helps alot.........took about 10 mins.
Re: (Vibe_dude)
Posted: Sun Apr 30, 2006 7:31 am
by Mach2
I'll stay with the stock belt to 50,000 miles, then change it. I'll get one now and keep it in the car until then, just in case.
Re: (Mach2)
Posted: Sun May 24, 2009 2:21 am
by Mojo72
I just changed the accessory belt at 82K+ miles w/ a Dayco Rib (Part #5060725) belt. I didn't take off the RF tire, but was able to put an old wire hangar to good use in pulling up the belt to loop it around the tensioner pulley. That said, I doubt that I could have done it without an extra set of hands to hold the belt in place while threading it on the other pulleys. Good to go.
