Adding 12V port in the front-center compartment of a 2006
Posted: Wed Apr 05, 2006 1:38 am
by meall
Hi,As far as I can remember , Vibe's model from 2003 to 2005 had a 12V port into the front-center compartment in between the 2 front seats. The 2006 Vibe don,t have this. I ask my GM garage if that could be added to the 2006, and they could not find a peice for that in their catalog. So far, the guy pointed out that there is a cable there (when you remove the module), but he was not sure it could be used as a 12V plug. The hole is already there in the rear compartment.Any idea on where/how to add this? That may be usefull in camping this summer to plug a refregerated termos.Thanks
Re: Adding 12V port in the front-center compartment of a 2006 (meall)
Posted: Wed Apr 05, 2006 1:54 am
Is this the thread you were looking for?http://forums.genvibe.com/zerothread?id=13711
Re: Adding 12V port in the front-center compartment of a 2006 (joatmon)
Posted: Wed Apr 05, 2006 1:56 am
by Mrizzle05
thats wierd... my 05 and fiances 06 had the outlet!!! thats crazy.
Posted: Wed Apr 05, 2006 4:28 am
by orbix
Huh. My 50 doesn't have it... I think the change was from the 04 to the 05 model years generally, though there certainly is some variation.
Re: (orbix)
Posted: Fri Apr 07, 2006 7:00 am
by new05vibeowner
My 05 didn't have one either, and the dealer wanted $21 for the part plus installation. Went to Wal-Mart, bought a generic outlet for $5 and wired it myself. Took less than 15 minutes.
Re: (new05vibeowner)
Posted: Sat Apr 08, 2006 6:00 am
by meall
To wire it yourself, you cut the wire there and solder? what is your method?Thanks
Re: (meall)
Posted: Sat Apr 08, 2006 1:37 pm
by GMJAP
Quote, originally posted by meall »To wire it yourself, you cut the wire there and solder? what is your method?ThanksAs joatmon already posted, please see this thread:http://forums.genvibe.com/zerothread?id=13711It also applies to the 2006.
