HELP! I can't find the fuse panel!
Posted: Mon Mar 20, 2006 3:23 am
by Marco922
I have an '03 Vibe and I can't find the fuse panel. I have found the one under the hood, but isn't there one inside the car?
Posted: Mon Mar 20, 2006 3:27 am
by Waxler6942
Above the drivers feet there is a fise panel, It has a cover on it you have to pull the cover off. If you kinda lay on you back and look up it is there
Re: (Waxler6942)
by damronjr
Yep, under the dash on the drivers side. Should be right above your left knee.
Re: HELP! I can't find the fuse panel! (Marco922)
Posted: Mon Mar 20, 2006 3:29 am
it's on the driver's side, up under the dash. You have to come from the floor up to get to it, but, if you pulled out the storage compartment on the left side of the dash (the one under the dimmer switch and mirror controls), you could see the top of it. unfortunately, the fuses are on the bottom of it, it's inconvenient. Good luck, the location of it is less than idealedit2 I got beat on this one
Posted: Mon Mar 20, 2006 3:48 am
by binary
yep, it's a behotch to get at... combine the fact that it has a cover, uses mini-fuses, and I have less than small fingers all made swapping out a fuse a situation that was rated R for mature audiences only.
Posted: Mon Mar 20, 2006 4:04 am
by Marco922
I found it....thanks!
