TRD intake vs. Injen
Posted: Tue Jan 17, 2006 2:48 pm
by Puckman27
any difference between the TRD CAI or the Injen for the Vibe GT? Do you guys think the TRD is a good buy if i can get it for about $150?
Re: TRD intake vs. Injen (Puckman27)
Posted: Tue Jan 17, 2006 9:20 pm
by damronjr
Let me tell you, I have seen firt-hand how much better the TRD fits over the Injen. If I could find a good deal I would replace my Injen with a TRD quick, especially if you are going S/C.
Re: TRD intake vs. Injen (damronjr)
Posted: Wed Jan 18, 2006 12:58 am
by Mavrik
Injen one fits fine in my Vibe and no cel lights. I've heard different stories about TRD ones but those were on the Vibe GT. I got the base.
Re: TRD intake vs. Injen (Mavrik)
Posted: Thu Jan 19, 2006 3:11 am
by Psychobroker
One big advantage: Injen's is C.A.R.B. exempt, TRD's isn't made for a Vibe, so it's only exempt on the Matrix.
Re: TRD intake vs. Injen (Psychobroker)
Posted: Thu Jan 19, 2006 3:37 am
by damronjr
Quote, originally posted by Psychobroker »One big advantage: Injen's is C.A.R.B. exempt, TRD's isn't made for a Vibe, so it's only exempt on the Matrix.Hmm, interesting.....
Posted: Thu Jan 19, 2006 5:45 am
by Psychobroker
Quote, originally posted by damronjr »Hmm, interesting.....Yep, same goes for AEM, so when you're due for a smog check (in CA), you better be ready to either a) reinstall OEM airbox or b) shell our for an Injen CAI or K&N Typhoon (SR), the only 2 CARB-exempt a/m intakes for the Vibe that I'm aware of.I plan on going with a Typhoon, mainly because I won't have to stress about hydrolock anymore, and the filter's easier to get to.
Posted: Thu Jan 19, 2006 7:43 am
by AKLGT
Quote, originally posted by Puckman27 »any difference between the TRD CAI or the Injen for the Vibe GT? Do you guys think the TRD is a good buy if i can get it for about $150?biggest issue with the TRD CAI on the VGT (and it is carb legal at least up here and they go by the CA emissions) is that most always it will throw a CEL on the VGT. doesn't seem to have a problem with 1ZZ but the 2ZZ that CEL will light up like a sore thumb. i found the only remedy aside from taking it out, was to get the unichip.... at least that was my rationalization for it originally....
Posted: Thu Jan 19, 2006 7:55 am
by northvibe
the cel doesnt go away after a while of driving?
Re: (northvibe)
Posted: Thu Jan 19, 2006 9:24 am
by Roadpig
I have an Injen CAI on my GT and the CEL was on for the first hour or two of driving (over a period of about two days) and it hasn't been on since.
Re: TRD intake vs. Injen (trdvibe)
Posted: Thu Jan 19, 2006 3:28 pm
by Puckman27
how does one intake throw a cel and another not? that makes no sense... they're just empty pipes, and we plug in the air sensor! i yi yi
Posted: Thu Jan 19, 2006 3:54 pm
by northvibe
i think its because you have more air going into the intake, so the computer needs to relearn the mix.
Posted: Fri Jan 20, 2006 2:47 am
by vibedrvr04
I got the Ingen CAI from P-Tuning and never had a CEL problem with it. It just dropped right into place on install and the filter wasn't really that bad to get to...just takes a little work. I wouldn't go for the short-ram. A) it looks kinda cheesy and B) i want COLD air, not hot air from the engine bay...after all...that's the whole reason for the CAI right? But hey, that's just me...to each their own. That's the beauty of modding a car.
Re: (vibedrvr04)
Posted: Sat Jan 21, 2006 5:31 pm
by Puckman27
yeah i dont quite get the point of a short air intake. i had one on my grand am, all it did was make it sound a lil better. other than that i think it took power away cuz its sucking the hot air in, unlike the factory setup that had a cover over it and it was sucking in somewhat cooler air. anyhoo, i know i was asking about the TRD and Injen intakes, but whats up w/ the AEM for a GT? it seems like nobody has it.
Re: (northvibe)
Posted: Sun Jan 22, 2006 10:40 am
by AKLGT
Quote, originally posted by northvibe »i think its because you have more air going into the intake, so the computer needs to relearn the mix.ya something like that. and no, mine would never go away until i installed the unichip. i even tested it out later and turned off the unichip. the CEL came back on. haven't heard of any problems with the base engines though, just for some odd reason, the GT and mostly with the TRD CAI. doesn't make any sense to me either!
Posted: Mon Jan 23, 2006 12:02 am
by ToolGuy
Most CAI systems on vehicles do not throw codes... I have had two on my cars and never a code with them. The computers relearn themselves or you can force a relearn by disconnecting the battery. Since it seems GT's are susceptible to codes using a CAI, I would be interested in knowing exactly what the code was or the verbiage of the actual code shown, defined in the service manual.
