rpm problems, car desn't go over 6 rpm
Posted: Tue Jan 10, 2006 5:13 am
by lucho
check engine light went on, and my rpm is low in reaction and it doesn't reach to the top, i want to know if anybody experience this same problem, or i just have to go to the makanic... someone said something about a celunoid, or it could also be the computer
Re: rpm problems, car desn't go over 6 rpm (lucho)
Posted: Tue Jan 10, 2006 5:58 am
by drunkenmaxx
nos ayuda si puedes decirnos cual tipo de vibe tienes.
Re: rpm problems, car desn't go over 6 rpm (drunkenvibe)
Posted: Tue Jan 10, 2006 6:19 am
Quote, originally posted by drunkenvibe »nos ayuda si puedes decirnos cual tipo de vibe tienes.His other thread says he is looking for tail light covers for his 2003 Vibe GT.If it was my car, the first step would be to take the car to an auto parts store, like AutoZone, or one of the others that will hook up a scan tool and read out the error codes that are causing the check engine light. There are places that will do this for free. That will give some indication what the car's computer thinks the problem is, and why it won't let you go into lift.If you can find out what the code is, that will help us try to figure out what the problem might be. If you are still under warranty, then I'd say just take it back to the dealer.
Posted: Tue Jan 10, 2006 6:20 am
by ColonelPanic
Basically there has been a failure somewhere that has triggered the computer to run the engine at a reduced level of power to prevent damage... Have you added anything aftermarket to the engine? Particularly a cold air intake? If so, you probably have a fried mass airflow sensor...Check engine light on steady or flashing, by the way? At any rate, Joatmon's advice is good. Find what the code is and go from there.
