Tire Inflation
Posted: Fri Jan 06, 2006 10:42 pm
by fsfrick
What is the proper tire inflation (PSI) for a 2004 Vibe? Where is the tire inflation sticker, or where is the info in the user's manual?FSF
Re: Tire Inflation (fsfrick)
Posted: Fri Jan 06, 2006 11:19 pm
by Raven
32 psi I think it's on the sticker in the glove box.
Re: Tire Inflation (Sunny)
Posted: Sat Jan 07, 2006 1:00 am
by fsfrick
Sunny,Thanks a lot!FSF
Posted: Sun Jan 08, 2006 9:37 am
by binary
Most vehicles have it on the driver's side door. I think many manufactures standardized (if you can call it that) after the whole firestone/ford disaster.Regardless, my '05 has it on the door.
Re: (binary)
Posted: Sun Jan 08, 2006 10:31 am
by Raven
Quote, originally posted by binary »Regardless, my '05 has it on the door.My '06 has it on the door also but my '04 had it in the glove box and fsfrick has an '04.
Posted: Sun Jan 08, 2006 12:08 pm
by joholste
check your actual tires, it should tell you the max PSI, if you're going for max MPGs run about 2PSI underneath max, if you want more comfort then i would suggest 32-36
Re: (joholste)
Posted: Sun Jan 08, 2006 12:17 pm
by mcgusto82
36 mpg improve fuel economy. but the ride is a little stiff on low profiles. it feels fine on stock tires.
Re: (joholste)
Posted: Sun Jan 08, 2006 12:38 pm
by GMJAP
Quote, originally posted by joholste »check your actual tires, it should tell you the max PSI, if you're going for max MPGs run about 2PSI underneath max, if you want more comfort then i would suggest 32-36In general, though, you should set the tire pressure to the vehicle maker's recommendation, not the tire's.
Posted: Mon Jan 09, 2006 12:53 pm
by 48-remi
I run my tires at 32 psi front and 30 psi rear. My wife's Maxima is set up the same (33/30) . The weight distribution on the Vibe is 60/40 front and rear so the 30 psi on the rear makes the ride less jumpy.
Re: (Sunny)
Posted: Fri Jan 13, 2006 9:41 am
by binary
Quote, originally posted by Sunny »My '06 has it on the door also but my '04 had it in the glove box and fsfrick has an '04.Ah - good catch. Thanks!
