Kill Switch?
Posted: Wed Nov 16, 2005 7:55 am
by June
My vibe came with the power package but minus the alarm. I don't have the cash for an aftermarket alarm now so I'd like to install a kill swith for those time when I park in questionable areas. I'm thinking a fuel pump kill switch would probably be easy to set up. What do you think? Thanks for the help.June
Posted: Wed Nov 16, 2005 9:15 am
by Jahntassa
It'd be pretty easy, you just need to find the wires that lead to the fuel pump, and i'd get a relay to handle it.. I can explain the setup if someone with a service manual can ID the wires..
Re: (Jahntassa)
Posted: Wed Nov 16, 2005 10:00 am
by Mavrik
Well simply look in your trunk, the access to the fuel pump is under the floor, so are the wires.
Re: (Mavrik)
Posted: Wed Nov 16, 2005 10:36 am
by JohnC
Quote, originally posted by Mavrik »Well simply look in your trunk, the access to the fuel pump is under the floor, so are the wires.Or there should be a fuel pump relay under the hood.
Re: (JohnC)
Posted: Wed Nov 16, 2005 12:37 pm
by mcgusto82
a starter kill relay might be easier to install since the wires are basically in plain sight.
Re: Kill Switch? (Mavrik)
Posted: Wed Nov 16, 2005 10:02 pm
by Baltovibe
Quote, originally posted by Mavrik »Well simply look in your trunk, the access to the fuel pump is under the floor, so are the wires.I thought the fuel pump was under the rear seat?http://forums.genvibe.com/zerothread?id=19724
