XM on the factory radio - Info Sheet
Posted: Sun Nov 13, 2005 11:34 pm
by ZubenElGenubi
Just thought I'd post this for future reference. It's a PDF file on how to use XM on the factory radio (when equipped). I found it at XM's website (you can generate one for any vehicle where XM is available as an option).
Attached files XM-Vibe.pdf (136.5 KB)
Re: XM on the factory radio - Info Sheet (ZubenElGenubi)
Posted: Mon Nov 14, 2005 12:41 am
by mcgusto82
So is the XM tuner a seperate unit on the 06's or is it built in the HU.I don't know if you guys know, but the 04 without cd changer has a 12 pin harness. The one where the changer goes to. This harness goes all the way to the rear pass side pocket. Is this where the XM tuner is located on the later models?
