brake problems after 15K miles?
Posted: Sat Oct 22, 2005 11:37 am
by pingber
Have any of you had to have the front pads replaced after 15K miles? My vibe is making grinding sounds when stopping, but it doesn;t happen all of the time, sometimes gone for a day or two. Seems to be worse in wet weather ...any ideas????
Re: possible brake problems after 15K miles??? (pingber)
Posted: Sat Oct 22, 2005 11:41 am
by millster
Mine always did that. The exposed disc rotors will develop a little surface rust after the car sits for a bit, especially in wet conditions. The car will sound a bit raspy when braking until the rust is worn off.
Re: brake problems after 15K miles? (pingber)
Posted: Sat Oct 22, 2005 11:55 am
by Raven
If it does it when you first drive on a wet day, it's perfectly normal. A fine coating of rust forms very quickly on the discs but wears off after you drive a short distance and brake a few times. Don't worry.Welcome to Genvibe. Same question, same answer eh Millster?
Posted: Thu Oct 27, 2005 12:00 am
by jasonvibe
If it does it ONLY after sitting in an overnight rain...NORMAL. Noise should go away after one or 2 stops. Otherwise have the brakes checked.
Posted: Tue Nov 01, 2005 12:41 pm
by binary
On a humid or misty day, rust can show up much sooner... a couple of hard stops cleans the rotors up and you'll have a quiet drive after.
Posted: Tue Nov 01, 2005 12:46 pm
by Mr. Poopypants
Living in the hills of western PA, I have to change my brakes after 15,000 miles, so for me, new pads after 15k is kinda normal.
Re: brake problems after 15K miles? (Mr. Poopypants)
Posted: Wed Nov 02, 2005 12:29 am
by russ257
i had to replace mine at around 18 and again now at 35
Re: brake problems after 15K miles? (russ257)
Posted: Wed Nov 02, 2005 4:46 am
by Mr. Poopypants
Quote, originally posted by russ257 »i had to replace mine at around 18 and again now at 35Yep, I changed the pads to ceramic, hopefully they last a little longer.
Posted: Thu Nov 03, 2005 2:36 am
by binary
Quote, originally posted by Mr. Poopypants »Yep, I changed the pads to ceramic, hopefully they last a little longer.Less brake dust too - I would hope?
Re: brake problems after 15K miles? (binary)
Posted: Thu Nov 03, 2005 3:33 am
by Mr. Poopypants
Yep, MUCH less.
Posted: Thu Nov 03, 2005 7:59 am
by jasonvibe
I hope I am not doing the brakes every 15k. I did them on my last car every 25. Because the wife drives 90% city and the sliders would stick on the driver's side caliper. The passenger's side were only half worn. Also the "better" pads from Autozone made more dust than anything else I had ever used. Advance's silver pads have less dust but less grip. This is based on my last car.
