I think I blew my strut......HELP!!!
Posted: Thu Oct 06, 2005 12:49 pm
by djnewm
Well, I think I may have done it. I was driving in a not so good parking lot and all of a sudden, my front passenger side is making a knocking noise on all bumps, big and small.I have lowered it w/ the Springtech springs w/ 17" wheels w/ 205-40-17 tires. I'm hoping I can get parts cheap since I need to drop a grand on a deposit and rent for a house that I'm movin into starting November.Can anyone tell me what it might be or any suggestions what it might be. Thanx in advance!!!!
Re: I think I blew my strut......HELP!!! (djnewm)
Posted: Thu Oct 06, 2005 12:50 pm
by djnewm
Oh yeah, my car does have 95k miles on it. Plus I drive on not so good roads in Northeastern Ohio.
Posted: Thu Oct 06, 2005 1:03 pm
by ZubenElGenubi
Sure sounds like a strut, but could also be loose lugnuts on your wheel. Since you mentioned that you dropped the car, you might also check the two 22mm bolts holding the strut to the suspension to make sure they're tight.
Re: I think I blew my strut......HELP!!! (ZubenElGenubi)
Posted: Thu Oct 06, 2005 1:08 pm
by djnewm
Will check the 22mm bolts.When the car was parked, rocked the front end several time to hear where the sound was comin from. It sounds like it's coming from the top. I check the Strut Brace Bar and the nuts holding that on, and they all were tight. Pretty sure that it's not the lugs, but will check those too.
Posted: Fri Oct 07, 2005 2:46 am
by Mavrik
my Vibe made that noise from the left front for about a week. Hasn't since then... I checked everything, from wheel lugs, tightened my front strut tower bar, the nut on top of the strut mount...
Re: I think I blew my strut......HELP!!! (Mavrik)
Posted: Fri Oct 07, 2005 3:17 am
by djnewm
thanx, I will do that now. Went to NTB and they gave me an estimate........... are u ready?? Here goes......$954I took the paper they gave me, went home and grabbed my bottle of vaseline. They said it was the strut mountsThis price was including 2 struts (2x $158), 2 strut mounts (2x $142), 2.7 hrs labor, alight ($64.99, if they can get it on the aligner), plus tax.......they said they have to get the parts from the dealer, but they could get some KYB struts for about $40 less per strut. WOW!!Later, I went home and priced http://www.partszoneonline.com and found struts to be $98, and strut mounts to be $89. So we'll see how it goes.
Posted: Fri Oct 07, 2005 3:37 am
by ragingfish
One of the reasons I'm opting against lowering the new car...even though I loved the way it made the vibe look. suspension is MAD expensive to fix if it breaks!
Posted: Fri Oct 07, 2005 3:40 am
by djnewm
A BIG THANX TO MAVRIK!!Took a 19mm socket, tightened it up, and JOILA!! Took a test drive and no noise. Now I'm gonna go buy me some new parts seeing that I just paid myself $954.Think I'm gonna go stick it to NTB.
Posted: Fri Oct 07, 2005 3:51 am
by rlfreese
when i installed my springs my left front 19mm came loose after a week and did the same thing. I rechecked everything before taking it to a shop though. Ima mechanic and refuse to pay anyone to fix what I can fix.
Posted: Fri Oct 07, 2005 4:04 am
by Mavrik
Quote, originally posted by djnewm »A BIG THANX TO MAVRIK!!Took a 19mm socket, tightened it up, and JOILA!! Took a test drive and no noise. Now I'm gonna go buy me some new parts seeing that I just paid myself $954.Think I'm gonna go stick it to NTB.ouch well at least I know what it would cost me if that had been my problem to. But glad yours solved up to with tightening that nut on the top. Mine didn't actually seem all that loose... but I tightened it up anyway. Glad to help.
Posted: Fri Oct 07, 2005 4:29 am
by djnewm
RLFREESE:Yeah, I like to do the work myself. I'm a cheap college student, plus I gotta put $1000 down on a house to rent.Thanx again
Posted: Fri Oct 07, 2005 5:14 am
by rlfreese
yeah, i know how the rent deposit is, where you at that it is that much. I used to live in northern va and my rent on a 1 BR apt was $1200 w/ military discount and that was cheap. I hate it up there. The BAH pay for the army doesnt even amount to any rent in the area.
