Front tire wear!
Posted: Thu Sep 08, 2005 1:36 am
by ShadowRuleZ
So this is my first FWD car that we've put a few miles on. About to rotate the tires here, and the front (still on factory alignment) are more worn on the outside than the inside. Anyone else see anything like this? The rears are fine.
Re: Front tire wear! (ShadowRuleZ)
Posted: Thu Sep 08, 2005 3:22 am
by Mavrik
fast cornering?
Posted: Thu Sep 08, 2005 3:52 am
by rlfreese
mine did the same thing. the rsa's are crap and wear easy under heavy driving. i haul alot of stuff and have been doing alot of moving and stuff. i noticed when i dropped my car that the tires were worn more than they should be for factory stuff on 10000 miles.
Re: (rlfreese)
Posted: Thu Sep 08, 2005 12:18 pm
by binary
Quote, originally posted by rlfreese »mine did the same thing. the rsa's are crap and wear easy under heavy driving. i haul alot of stuff and have been doing alot of moving and stuff. i noticed when i dropped my car that the tires were worn more than they should be for factory stuff on 10000 miles.Yep, the OEM are just good enough to get you off the lot and keep GM from getting sued. Other than that - you're on your own.I don't expect these tires will last 20k.
Posted: Thu Sep 08, 2005 1:03 pm
by JohnC
Get everything documented with the dealer, there is a decent chance of getting a new set of tires if you identify the problem and keep complaining to the dealer and factory. My OEM Continentals were gone by 13k miles, mine had a bad camber problem that the dealer did not fix correctly the first try. At 44k I am on my 3rd set of tires. Good luck.
Posted: Thu Sep 08, 2005 10:44 pm
by ShadowRuleZ
These are stock RSAs. The wife drives the car, so it's not fast cornering. And we have done a bit of moving, but that was 15k miles ago. It hasn't been loaded up since then.If I get a chance, I'll see if I can stop into the dealer about it.
Posted: Thu Sep 08, 2005 10:56 pm
Are you running proper tire pressures?
Re: (ragingfish)
Posted: Fri Sep 09, 2005 2:38 am
by Mavrik
improper tire pressure will only cause the following wear patters... worn out tires on inside and outside tread caused by low on pressure. Or worn out in in the middle tread by to much pressure in the tires.Wear on outside only or inside only can usually be alignment issues or driving habits... at least by my experiences in the shop.
