Different tires? pros/cons
Posted: Wed Dec 11, 2002 12:51 am
by Nemo6321
Since I am a total n00b, I have a question. Becasuse Vibe is front driver, does it pay to have front wheels wider than back ones? What would happend?
Re: Different tires? pros/cons (Nemo6321)
Posted: Wed Dec 11, 2002 4:22 am
by Sub-Vibe-R
It will look very stage, wider tire in front. If you want to have wider tire, change the 4 tires. with that, will be also easier for tire rotation.
Posted: Wed Dec 11, 2002 1:51 pm
by Flip-Side
This is the only time you would want wider wheels on the front. Drag racing. Traction is horrible in wet/snow/dirt.
Re: Different tires? pros/cons (Flip-Side)
Posted: Fri Dec 13, 2002 9:44 am
by MadBill
Since my bare bones base Vibe does not have ABS, I was toying with the thought of using taller & wider rears, just for the Street Machine image. Probably not a good idea though, as it would screw up cornering balance and preclude tire rotation...
