how do you get the stock speakers out of the doors...
Posted: Wed Aug 03, 2005 5:52 am
by NascarXprt
ive tryed drilling and no privail. cant get through one rivet. what size bit do i need for this proccedure.
Re: how do you get the stock speakers out of the doors... (NascarXprt)
Posted: Wed Aug 03, 2005 10:28 am
by ColonelPanic
Ugh, it isn't pleasant. I'm not sure what size bit I used, but I do have the pack of rivets I used to reinstall the stock speakers out in the car. I'll get outside tonight and make a note of what size they are. Perhaps that will help...It took quite a bit of drilling for mine, those things are pretty stubborn!
Re: how do you get the stock speakers out of the doors... (ColonelPanic)
Posted: Wed Aug 03, 2005 10:29 am
by Mr. Poopypants
IIRC, it was a 1/4" bit that I needed to drill out the rivets.
Posted: Wed Aug 03, 2005 10:56 am
by Jahntassa
Yeah, use a larger bit. You just need to pop the head off the rivet so it'll fall out the other side. You need a drill with torque, and you need to push on it..
Re: (Jahntassa)
Posted: Wed Aug 03, 2005 2:13 pm
by jeffgtx
depending on what youa re installing, you dont need to remove teh bracket at all.on the vibe, i removed teh stock speakers and put teh blau's in that bracket as is.in teh vue, i tore the ridge off teh bracket and the speakers fit fine.see my post hereif you wanna try it
Re: (jeffgtx)
Posted: Wed Aug 03, 2005 3:19 pm
by NascarXprt
im installing the DUAL audio 6-1/2" 140watt 3way illuminitieshttp://
www.bestbuy.com/site/ol...09826
Re: (NascarXprt)
Posted: Wed Aug 03, 2005 3:30 pm
by jeffgtx
cant tell for sure from that, but it looks like they dont have an outer lip, you should be able to mount those right in without drilling teh rivets to me.
Posted: Wed Aug 03, 2005 8:31 pm
by Jahntassa
Keep in mind, you'd be destroying the stock speakers that way...
Posted: Fri Aug 05, 2005 8:55 am
by NascarXprt
now how do you get the speaker out of the bracket?
Posted: Fri Aug 05, 2005 9:28 am
by Jahntassa
Destroy it! Basically..you need to rip the cone out..you can use a knife to cut the outer surround of the speaker.. then use whatever you can to break the inner plastic supports on the magnet. And voila! Speaker mounting bracket.
Re: (Jahntassa)
Posted: Fri Aug 05, 2005 10:44 am
by jeffgtx
yayaya destroy!!!!what i did was pull the center of the cone out and the rim will want to rip off the outer bracket (its just glued on, no cutting neccesary if you pull slow and steady) then i used a cutter to cut the plastic pieces at the outer rim. see picture from cohocarls post:
