Where, physically is the beeper located?
Posted: Tue Jun 21, 2005 12:22 pm
by jeffgtx
the thing that beep when the keys are in and the door is open and the seat belt isnt on, etc.sounds like its behind the speedo?true?easily accessible or does it require upper dash removal?
Re: Where, physically is the beeper located? (jeffgtx)
Posted: Tue Jun 21, 2005 12:31 pm
by Mase
No dash removal necessary.-Pull the entire shroud off the instrument cluster.-Remove the top/center screw.-Undo the 2 clips on the bottom of the cluster.-Pull the cluster out, and unclip the 2 wire harnesses.-Unscrew the rear cluster cover.-You'll see the piezo electric buzzer encased in a big black cylinder.-Pry it off.Attached is a pic, courtesy of WorkinMatrix @ matrixowners.com
Posted: Tue Jun 21, 2005 12:33 pm
by ColonelPanic
It's built into the gauge cluster itself, I do believe. Sounds like you have the same idea I once had. That horrid cheapo radio shack piezo element buzzer thingy has to go! I don't know what those guys were thinking when they designed that. Gimme chimes, dang it! --EDIT-- That above post snuck in while I was coming up with this one... Has anyone successfully installed a different buzzer, such as one that doesn't suck, for instance? Inquiring minds want to know, that damn thing sucks!
Re: Where, physically is the beeper located? (ColonelPanic)
Posted: Tue Jun 21, 2005 12:44 pm
by jeffgtx
thanks Mase.... dateline saturday... me vs piezo!i took a look at the post on matrix owners. he jsut removed it, he did not replace it.yes CP, you and i are of teh same thought here. that thing hurs my brain.i wanna hook up the voice from mission to mars when the micro meteor goes thru the hull."50% atmosphere" hahahai am gonna go to the parts store and look for replacments tomorrow.
Posted: Tue Jun 21, 2005 5:19 pm
by ColonelPanic
Cool. I'm wondering how that buzzer works - we have 3 different modes basically - the fast beeping for the key, the slower for the seat belt and the steady beep for the lights on warning... Not sure if that is all done in the buzzer assembly itself, or if that is done somewhere else which varies the signal gonig into the buzzer.Definitely would be interesting to see this work out. If it works, I need to find the chime thingy out of a wrecked Hyundai... I don't know why, but that mechanical diiiiing diiiiiiiiiiiiiinnnngg sound is just cool to me. (removed)!
Posted: Tue Jun 21, 2005 5:23 pm
by 03VibeGT6Spd
Is that also the Reverse beeper? I wish they would have mounted that one outside the car. LOL
Re: (03VibeGT6Spd)
Posted: Tue Jun 21, 2005 5:27 pm
by ColonelPanic
Yep, I'd say the annoying beep you six speeders have probably comes from the same place. I can't remember what car was being reviewed or where, but I do remember this being said: "It beeps like a forklift when in reverse."
Re: (ColonelPanic)
Posted: Tue Jun 21, 2005 5:31 pm
by 03VibeGT6Spd
Quote, originally posted by ColonelPanic »Yep, I'd say the annoying beep you six speeders have probably comes from the same place. I can't remember what car was being reviewed or where, but I do remember this being said: "It beeps like a forklift when in reverse." Forklift heck no!It sounds like dumptruck!
Re: (03VibeGT6Spd)
Posted: Tue Jun 21, 2005 5:32 pm
by ColonelPanic
lol! Maybe we'll find a successful mod to eliminate the dump truck action.
Re: (ColonelPanic)
Posted: Wed Jun 22, 2005 3:04 am
by Mase
Quote, originally posted by ColonelPanic »lol! Maybe we'll find a successful mod to eliminate the dump truck action. Already done. Cut this red/black wire on your cluster harness [see attached pic]
Re: (Mase)
Posted: Wed Jun 22, 2005 4:28 am
by jeffgtx
line the reverse indictor? that may come in handy for my mirror mod.
Re: (jeffgtx)
Posted: Wed Jun 22, 2005 10:41 am
by mcgusto82
why would you guys want to remove that beeper. if it's beeping, something is wrong. once it's fixed, it goes away. if you guys don't like wearing belts... shame on you.
Re: (mcgusto82)
Posted: Wed Jun 22, 2005 10:51 am
by jeffgtx
i am not removing, i am replacing with something that doesnt hurt my brain.CP - i am 95% sure teh piezo is not controlling the three beep segments. i cant remember where, but i saw the timing algorythm that put it in teh three timed beep modes, and i dont think that is contained within the little black thing.I'll need to doublecheck that.
Re: (mcgusto82)
Posted: Wed Jun 22, 2005 11:08 am
by ColonelPanic
Quote, originally posted by mcgusto82 »why would you guys want to remove that beeper. if it's beeping, something is wrong. once it's fixed, it goes away. if you guys don't like wearing belts... shame on you.Thank you for your concern, however removing the buzzer all together does not appear to be the goal of this project, at least from what I can tell. I know I'm not interested in going around and defeating safety features... Instead, I just think that dumping the "piezo crap" buzzer in favor of something a little more pleasant sounding would be a nice project...
Re: (ColonelPanic)
Posted: Wed Jun 22, 2005 8:43 pm
by mcgusto82
ohh. well then.. get to work
