				Glove Box Light?
				Posted: Mon Dec 02, 2002 4:39 am
				by a58vette
				Apparently there is no glove box light.  So i am going to install one and am just curious if anyone has done this before and if so how they did it and pictures if available.
				Re: Glove Box Light? (a58vette)
				Posted: Mon Dec 02, 2002 4:41 am
				by Sub-Vibe-R
				You're wright, there's no glove box light. I haven't put one in mine but I'm going to install some light under the dash, to light our foot.
				Posted: Sun May 15, 2005 12:39 pm
				by jeffgtx
				i want to do this now.  any one else done it?
				Re: Glove Box Light? (jeffgtx)
				Posted: Sun May 15, 2005 12:57 pm
				by damronjr
				I shouldn't imagine that it would be too hard.  With all the leds and such being run lately, a light with a switch shouldn't be too difficult.  If you want it to turn on when you open it, that might be a little harder.  I'm sure there'll be some inputs on this.
				Posted: Sun May 15, 2005 1:47 pm
				by BruiserVibe
				I plan on putting lights in the glove box and also in the small storage compartment on the driver's side.  I'm going to wire them up to turn on when they open by mounting a rocker switch nearby so that when the door is opened, it flips the switch, and when closed, flips the switch again.  I'll post pics when I get it done.
				Posted: Sun May 15, 2005 2:14 pm
				by Altus
				I've done it - no pics (sorry) - but it was no big deal.  Found some LED accent lights, mounted them inside the glove box, and wired them to the wire that powers the accent lights for the cigar lighter.  I added a micro switch to the door for the on/off action.Easy, quick, and relatively painless....
				Re: Glove Box Light? (Altus)
				Posted: Sun May 15, 2005 3:15 pm
				by jeffgtx
				do you have part number or a link for where the micor switch can be had?
				Re: Glove Box Light? (BruiserVibe)
				Posted: Mon May 16, 2005 1:39 pm
				by Wimperdink
				use a pin switch or a reed switch for clean look.  Need one I have lots of both.
				Re: Glove Box Light? (Wimperdink)
				Posted: Mon May 16, 2005 1:51 pm
				by jeffgtx
				well since youa re offering whats the difference?  any pics, or alink to what they look like?thanks
				Posted: Mon May 16, 2005 2:15 pm
				by Wimperdink
				Posted: Tue May 17, 2005 3:55 pm
				by jeffgtx
				ok, let me see if i can pass teh wimperdink switch quiz...reed switch: magnetic SPST such that in the presence of the other side, turns off or onpin switch- the kind with the 'post' sticking out and when the door pushes it in when closed and turns out the light?did i win?i guess i would like the reed type and then i can hook it up to a white LED setup right inside.do you have one i could buy?Jeff
				Posted: Wed May 18, 2005 2:06 pm
				by Wimperdink
				hey jeff check your IM's
				Posted: Fri May 20, 2005 2:56 pm
				by jeffgtx
				IM back atchya!
				Re: Glove Box Light? (silverawd26)
				Posted: Sun Dec 11, 2005 2:28 am
				by Mase
				I've done it in both the Matrix and Corolla.All it took was a momentary switch (normally closed), a 4000mcd led, resistor, and about 24 inches of wire.I'll try to take pics later.
				Posted: Sun Dec 11, 2005 11:31 am
				by Atomb
				just a thought...LEDs last for tens of thousands of hours and are pretty cheap.  why do you need a switch?  why not have it connected to the dash light circuit so that it's on whenever the dash lights are on?  it may even look interesting to have a red or blue or whatever glow surrounding the glove box door.   reminds me of pulp fiction for some reason!
				Posted: Mon Dec 12, 2005 9:08 pm
				by ToolGuy
				I was going to do this but it got dropped...However I do have the lamp, socket and a hand made bracket ready to go when I do pick the project back up.  I am using an old glove box switch and socket I picked up from a salvage yard many years ago; had it laying around in my parts dept!It has a door pin switch and there is a perfect spot on the top of the opening which meets the door so it will open and close or come on and off perfectly!  No pics now but I can take a pick of what I do have already...
