ac peeing on the floor....
Posted: Thu Jun 09, 2005 8:58 pm
by robdog
yesterday, 90 degree day, had ac on and after a while it just started basically peeing on my floor, mostly on the passenger side, but a little on the drivers side too. I saw it happen one time when I took off and it looked like somone was pouring water out of a glass, it was coming from right underneath the front glove box area. Any ideas or anyone have similar issues?????
Re: ac peeing on the floor.... (robdog)
Posted: Thu Jun 09, 2005 10:27 pm
by Vibe_dude
its a small drain line right under the passanger sides left foot......there is a pic of it here on the site somewhere.it needs to be zipped up tighter......it leaks alot on some ppls cars...toyota quality.
Posted: Thu Jun 09, 2005 10:46 pm
Re: ac peeing on the floor.... (Vibe_dude)
Posted: Thu Jun 09, 2005 11:00 pm
by ZubenElGenubi
Check the drain lines, for sure, but if they look intact, something could be blocking the drainline. My wife's RAV4 had the same problem and after two visits to the dealership, we found a small wooden dowel stuck in the drainline outside the firewall. Where that came from, we have no idea (but we weren't the original owner so we're thinking....KIDS!)
Posted: Thu Jun 09, 2005 11:08 pm
by Mr. Poopypants
Yep, it's the drain. It could be worse, it could be me peeing on your floor.
Re: ac peeing on the floor.... (Mr. Poopypants)
Posted: Fri Jun 10, 2005 4:51 am
by Vibe_dude
was it ur ac drain or another drain...i had alot of water on that side of my car this year but my drain hose is still attached.
Posted: Fri Jun 10, 2005 10:47 pm
by redlava
Bad Vibe, Bad Vibe. I am gonna rub your nose in that!!!Your sleeping outside tonight.
Posted: Sat Jun 11, 2005 10:46 pm
by waltman
I joined to say thanx very much!!!!! my wife said there was a smell so I checked our little Vibe and found passenger side to have a large "PEE" stain still wet.I searched and found this site and found my answer the tube was off I'll secure it.I'll see if dealer covers carpet,I did buy super duper warr.Leaks not covered of course.
Re: (ragingfish)
Posted: Mon Jun 13, 2005 5:14 am
by robdog
ok, thanks, I will have to look for this. It does only happen when the ac is on. So it is for sure an ac issue. If that pic shows up somewhere please post it in this post. I am not sure what I am looking for but I will look underneath there tonight and see if I see anything.
Posted: Tue Jun 28, 2005 5:38 am
by robdog
Yes, It was the drain, I pulled it out and still more water came out. I took it to the sink and water would not even flow through it. I stuck a screwdriver through it and cleared it out. Works like a charm now. not even a drop of water in the car. Thank you!!!
Posted: Fri Aug 05, 2005 6:11 am
by BaseViber03
Same here- I disonnected the hose and water came pouring out, from the black box. I blew into the hose, and bam!! It was cleared out of debris and now works lijke a charm. If it appears connected pull it off and see if there is a blockage that seems to be the trick! THANKS A MILLION!!ANOTHER DREADED TRIP TO THE DEALER AVOIDED!!!!!
