Speaker Question
Posted: Sat May 14, 2005 6:27 am
by kwman8
I found a set of subs in a custom box outside. I picked them up and want to install them in my 04 Vibe with Moon and Tunes package with the stock head unit. Do I have to buy an amp or can it work with the m&T amp? What would be the easiest place to wire it into.
Re: Speaker Question (kwman8)
Posted: Sat May 14, 2005 6:31 am
by damronjr
You could probably branch off of one of your speaker wires, but I wouldn't recommend it, it wouldn't sound very good, and it might even ruin your amp or sub(s). Best bet is to get a new amp and a scosche line converter. That would be the cheapest route for the best possible sound without getting a new head unit and amp(s).
Re: Speaker Question (damronjr)
Posted: Sat May 14, 2005 6:46 am
by kwman8
Thanks. Do you have any recomendations for a cheap amp?
Posted: Sat May 14, 2005 7:54 am
by damronjr
Quote, originally posted by kwman8 »Thanks. Do you have any recomendations for a cheap amp?The only places I can think of that might carry that kind of stuff would be like Walmart, Circuit City, or Best Buy. Ebay is a possibility, but kind of risky.
Posted: Sat May 14, 2005 12:21 pm
by Jahntassa
Depends on the subs. We'd need to know what subs they are. See if there's text on the front, else you'll have to take one out and see what it is. And no, you can't run it off the M&T amp.
Posted: Sun May 15, 2005 4:07 am
by kwman8
They are 2 Roadmaster RTS3200 6-1/2” woofers. I believe they are only 300 watts. Will it still be necessary to buy an amp?
Posted: Sun May 15, 2005 4:12 am
by ragingfish
There's no way you won't have to buy an amp. The factory amp is designed to power what's already in the car, nothing more.
Posted: Sun May 15, 2005 10:21 am
by Jahntassa
Any small amplifier will do. You probably don't want to get anything really bigger than 50w or 60w x2. 6 1/2's aren't really meant for power, and if you 'found it', they may already be blown...
Posted: Sun May 15, 2005 10:40 am
by Raivis
also if your hooking up to a stock stereo you need to buy a piece for the back to hook up RCA's i forget what its called its like an RF modulator they run about $20 at any stereo shop
Re: (Raivis)
Posted: Sun May 15, 2005 11:28 am
by damronjr
Yeah, that's the scosche line converter I was talking about. Like $17 at Walmart.
