What the H**l is holding the Stock speakers in place?
Posted: Thu May 05, 2005 3:16 pm
by NascarXprt
what is holding these speakers in and how do you get them off?
Re: What the H**l is holding the Stock speakers in place? (NascarXprt)
Posted: Thu May 05, 2005 3:36 pm
check out
http://forums.genvibe.com/zerothread?id=785 looks like rivets that need to be drilled out
Re: What the H**l is holding the Stock speakers in place? (joatmon)
Posted: Thu May 05, 2005 9:39 pm
by Mr. Poopypants
Quote, originally posted by joatmon »check out
http://forums.genvibe.com/zerothread?id=785 looks like rivets that need to be drilled outYep, I had to drill mine out. It's not hard to do. Keep in mind that you may have to get speaker brackets for your aftermarket speakers.
Posted: Fri May 06, 2005 12:44 am
by Jahntassa
Yup, rivets. The rear ones are farily easy to drill out, and most 6.5" speakers can screw directly to the metal in the rear door.The front doors are the same, but I left them in and gutted the speaker so I wouldn't have to get the spacers you'll need to clear the window..
