What is the correct pressure for stock tires?
Posted: Tue Apr 12, 2005 8:54 am
by victorzhu
And when should I measure the pressure? Thanks.
Posted: Tue Apr 12, 2005 8:59 am
by tnpartsguy
32 lbs. And it should be measured cold; ie 1st thing in the AM or at least 3 hours since the car was driven.
Posted: Tue Apr 12, 2005 9:15 am
by victorzhu
Thanks, so I did complete wrong, I usually measure the pressure after driving.
Re: (victorzhu)
Posted: Wed Apr 13, 2005 4:52 am
by utahindie
add 3 psi if warm
Re: (utahindie)
Posted: Wed Apr 13, 2005 12:30 pm
by Merzbow
I keep mine at 31
Posted: Fri Apr 15, 2005 2:23 pm
by zionzr2
Open driver door and look in the door well to your right....There is a label detailing tire pressure and weight limits for the vehicle.Mine it says 35lbs in front and 32 lbs in the rear though i have a AWD
Re: What is the correct pressure for stock tires? (silverawd26)
Posted: Thu Jun 02, 2005 12:11 am
by mcgusto82
a litle bit higher would probably get an improvement on gas mileage. mine arre set at 35. i drive 21 miles each way to work 6 days a week. my gas goes for 8 days @ 33mpg for the week.
Re: What is the correct pressure for stock tires? (mcgusto82)
Posted: Thu Jun 02, 2005 3:28 am
by drunkenmaxx
i rock em 32 front 35 rear
Re: (utahindie)
Posted: Fri Jul 01, 2005 10:03 am
by MrCritical
Correct tire pressures on driver's door or body where door and body meet. White laminated card.
