Line Output Converters
Posted: Thu Mar 31, 2005 8:44 am
by bh357
I need to hook up an amp to the factory radio (6 disk no M&T). Would this adapter work? http://www.cardomain.com/item/SCOFAI3 Also, does anyone have the connecter diagram or wiring chart for the factory radio? The only one I found is the one for the M&T package. I would like to splice the line level converter in behind the radio. Lastly, does the factory radio provide any sort of switched 12v line, that comes on when the radio is turned on?Thanks.
Re: Line Output Converters (bh357)
Posted: Fri Apr 08, 2005 2:12 am
by theangrydwarf1
Should work just fine. I don't see why it wouldn't.
Posted: Fri Apr 08, 2005 2:23 am
by GMJAP
Schematic for factory radio. The Antenna Amplifier supply output might give you 12v switched with the radio, but I'm not sure. You'll have to check.
Re: Line Output Converters (GMJAP)
Posted: Fri Apr 08, 2005 2:24 am
by GMJAP
24-pin radio connector diagram attached:
