leaking door seal
Posted: Mon Mar 14, 2005 8:52 am
by tadlag
I just bought a used 2004 vibe for my wife that has a rear door seal that leaks. the car has 31000 miles on it. can anyone tell me if this is a warranty issue or not?thanks,tadlag
Re: leaking door seal (tadlag)
Posted: Mon Mar 14, 2005 10:47 am
by Baltovibe
If you look at this thread, it appears the door seal is covered under warranty. Maybe the door needs adjustment?
http://forums.genvibe.com/zerothread?id=7907
Posted: Mon Mar 14, 2005 7:46 pm
it should be under warranty, unless there is some evidence of abuse, and the factory warranty is supposed to transfer with the car, not stay with the original owner.what is it leaking, air or water?
Posted: Tue Mar 15, 2005 7:29 am
by tadlag
water, it just streams in at the top rear curve of the door. i looked at the seal and it looks good.
Posted: Tue Mar 15, 2005 10:13 am
by 1badvibe
what i am about to tell you is top secret, ancient bodyman secret, shhhhhhhhhhh,put your window down, place your knee on the top of your inside door panel, grab upper part of your door and pull gently. this should elimate your leaks, if not repeat as needed, KEY STEP: roll window down!!
Re: leaking door seal (1badvibe)
Posted: Tue Mar 15, 2005 10:42 am
by scherry2
Quote, originally posted by 1badvibe »what i am about to tell you is top secret, ancient bodyman secret, shhhhhhhhhhh,put your window down, place your knee on the top of your inside door panel, grab upper part of your door and pull gently. this should elimate your leaks, if not repeat as needed, KEY STEP: roll window down!! do you work in a auto factory? thats how we fix them at work.
Re: leaking door seal (scherry2)
Posted: Tue Mar 15, 2005 11:32 am
by 1badvibe
body shop
