Where can you attach the tow strap?
Posted: Tue Mar 01, 2005 11:58 pm
by michaelgt
Has anybody pulled the Vibe out of the snow using a recovery strap? Where do you attach the hook/strap on the Vibe? I got stuck at the end of my drive last night, and could not move the car after I moved the snow. The Vibe was resting on the snow, and I could not get any movement pushing the car. I ended up opening the hood and attaching the strap to metal under the hood. Any other suggestions for the next time?
Re: Where can you attach the tow strap? (michaelgt)
Posted: Wed Mar 02, 2005 12:42 am
by scherry2
under the front end in the middle on the frame is a metal loop for towing
Posted: Wed Mar 02, 2005 1:47 am
by Atomb
i just saw the metal loop on the front end yesterday (right in the middle, hard to miss) ...i haven't checked under the back yet.
Re: (Atomb)
Posted: Wed Mar 02, 2005 1:54 am
by Mase
I'm almost positive there's nothing in the back. Would it be alright to just loop it around the rear torsion beam instead?
Posted: Wed Mar 02, 2005 2:49 am
by 03VibeGT6Spd
I wouldn't use the rear torsion beam, I have seen them bend in other cars. Then you have to replace it as well.
Re: Where can you attach the tow strap? (scherry2)
Posted: Wed Mar 02, 2005 3:40 am
by michaelgt
ThanksThere was snow all the way up to my grills, I shovel around but could not find it. As for the back, I did have the tow hook wedged into a spot on the metal support for the bumper, but I was not sure if it was strong enough to pull on it?
