Stock Amp
Posted: Sun Nov 17, 2002 10:01 pm
by BlackGTNJ
Does anyone with the stock amp have the speaker wiring diagram. I want to make sure I have all the positives and negatives correct?
Re: Stock Amp (BlackGTNJ)
Posted: Sun Nov 17, 2002 11:12 pm
by NovaResource
I have the service manual and can let you know later.
Posted: Sun Nov 17, 2002 11:13 pm
by pissedoffgokart
I posted this a while back, no has said it is wrrong yet!http://forums.genvibe.com/zerothread?id=1042
Re: Stock Amp 6 disc changer
Posted: Sat Nov 30, 2002 12:37 am
by ourvibe
Just new to this forum. Actually first forum I've been involved in. So hope I am asking questions OK.I have the factory 6 disc changer with 200 watt amp. Want to replace amp with 4 channel Alpine. Can anyone tell me if the output from the head unit is low or high level. (any idea on voltage level) Is there a wiring diagram that shows the head unit output/amp input. Thanks for help.
Re: Stock Amp 6 disc changer (ourvibe)
Posted: Sat Nov 30, 2002 12:59 pm
by pissedoffgokart
It's all line level my friend! Just plain ol' speaker leads.
Re: Stock Amp (NovaResource)
Posted: Fri Dec 06, 2002 8:18 am
by ourvibe
Anyway I could talk you into sending me a copy of wiring diagram for the two connectors that go into the 200 watt amp.It would help me out a whole bunch in replacing that piece of CR--Thanksquote:I have the service manual and can let you know later.
Re: Stock Amp (ourvibe)
Posted: Thu Dec 12, 2002 3:19 am
by shadow
I'd also love to have a copy of this diagram. I'd like to tap into the rear line leads at the stock amp and wire them to my Kenwood so I can push my Infinity Kappas. I'd be willing to host the picture on my web server!
Re: Stock Amp (shadow)
Posted: Sun Apr 06, 2003 8:39 pm
by rockinvibe
did you ever receive the wiring diagram for the stock amp. i am adding a sub, and would love to tap into the amp for a lead. please let me know @ stevetietjen@wideopenwest.com. Thanks, Steve
Re: Stock Amp (rockinvibe)
Posted: Tue Apr 08, 2003 4:15 am
by ourvibe
Never did get a copy of wiring diagram. I did figure it out myself.Everything seems to work OK and polarity checked out with voltage meter.NO GUARANTEES yours will be the same. In our car the wires to speakers change colour somewhere between amp and speaker. Maybe change from GM wiring harness to Toyoto. You should go right from speaker to amp and buzz out wires to confirm correct wires and polarity.What kind of sub do you plan to install.
Attached files radioconnectors.pdf (37.8 KB)
Posted: Tue Apr 08, 2003 4:19 am
by Sub-Vibe-R
Usualy, to make the difference between + and - on wiring, the neg. has the same color as the +, but with a black line.
