Cavailer issue need help!
Posted: Sat Jan 15, 2005 10:14 pm
by zionzr2
I also have a '02 cavalier (wife's car) its an automatic with a console shifter.... the issue is the the light under it is burrned out, so at night you cant see the letters....Is this something i can do my-self? I cant really see how to get under the console to get at whatever bulb i need....any help greatly appreciatedThanks
Re: Cavailer issue need help! (zionzr2)
Posted: Sun Jan 16, 2005 3:41 am
Wish I still had my 02 sunfire, I could go o ut there and poke and prod and figure it out myself...Sadly, though, I can't! Good luck though!If you do take it in to be changed, I can't see them charging a heck of a lot to screw in a light bulb...But then again, how many GM service techs does it take to screw in a light bulb?The world may never know!
Re: Cavailer issue need help! (ragingfish)
Posted: Sun Jan 16, 2005 5:35 am
by Devlop
I'm sure its just a peanut bulb that needs to be changed. Its been a while since I have taken one of those apart, but I'm sure there are just a couple of bolts inside at the bottom of the console. You'll probably have to take out some sort of pad at the bottom. There should be screws or bolts at the front also, perhaps in the cup holders. I'm not positive though, like I said, its been a while.
Posted: Sun Jan 16, 2005 8:48 am
by Carbman
If worse comes to worse my old 1983 ford T-Bird had that problem and Icould never find the light so I counted shifts from park and just got used to it after that anymore i dont even look at the gears from park one shift reverse, next shift nuetral, next shift drive. Dont know if this will help or not so good luck man.
Posted: Mon Jan 17, 2005 1:58 am
by ToolGuy
You will probably have to remove the shifter lever, the part you grab to shift it. And then remove the center console. The screws to remove the console are under round plugs and exposed screws throught the console. I used to write the serv manuls for these cars but it has been a long time...Like this...
Re: Cavailer issue need help! (MiVibe-ToolGuy)
Posted: Tue Jan 25, 2005 4:46 am
by zionzr2
Bulb Replaced.... bulb type (P194)Wont know till dark if its fixed for sure....Man thats a tight spot to workin though....had to pop the entire center console only would move a little bit.took about 20 minutes. to find the right tools and to wrestle the console.Chevy said they would glady do it for $60-80... I said NO! 20mins and $3.50 for a bulb.. I did it myself
Posted: Thu Jan 27, 2005 12:15 am
by ToolGuy
Cool, good job! Yeah right, one hours dlr labor for a bulb change, get bent!
Posted: Fri Jan 28, 2005 10:22 am
by micheles_bad_vibe
