Armrest Extension?
Posted: Tue Oct 19, 2004 9:33 am
by bjlarson
Does anyone know if there is an aftermarket armrest extension available?Thanks,Brian
Re: Armrest Extension? (bjlarson)
Posted: Mon Oct 25, 2004 6:26 am
by Merzbow
build one;)
Posted: Mon Oct 25, 2004 7:48 am
by GMJAP
What do you mean by armrest extension?
Posted: Sat Oct 30, 2004 4:21 am
by bjlarson
You know, the center armrest with the storage. By extension, I mean to increase it in height, for it is too low.
Posted: Sat Oct 30, 2004 11:53 am
by JohnC
My daughter made me a little pillow that sits on top of the armrest...works great. I use on in most of the vehicles I drive, seems like engineers design the armrest for short people only.
Posted: Sat Oct 30, 2004 11:07 pm
The armrest height is ok for me. What's your seat height? If you lower the drivers seat, the armrest is relatively higher.How much do you want to raise the armrest?
Re: Armrest Extension? (joatmon)
Posted: Sun Oct 31, 2004 1:21 am
by Raven
It's a good height for me too. I drive with the seat in it's lowest position. If you want to see a low armrest, sit in an '05 Vibe. When I got in, I leaned towards my right elbow as I always do and almost fell over into the passenger seat.
Posted: Sun Oct 31, 2004 5:31 am
by GMJAP
Quote, originally posted by bjlarson »Does anyone know if there is an aftermarket armrest extension available?Don't know of an aftermarket extension, but per the thread below, you can get & put in the higher armrest with storage tray (like in earlier models)http://forums.genvibe.com/zerothread?id=12602
Re: Armrest Extension? (GMJAP)
Posted: Sun Oct 31, 2004 6:08 am
by Raven
That was definitely a mistake to delete the extra storage compartment on the '05s but they have a much improved seat height adjustment. Instead of the big knob on the side , they have a lever. Pull up to raise and push down to lower. It even works when you are sitting in the seat!
Posted: Sun Oct 31, 2004 6:11 am
by Sputnik
Quote, originally posted by bjlarson »Does anyone know if there is an aftermarket armrest extension available?Thanks,BrianYeah do what we do - buy 4 baseboards 5/8th of an inch thick and run them up through the centre! I had my arm resting on them all the way home!
Posted: Mon Nov 01, 2004 10:38 am
by bjlarson
That would work perfect. I prefer to sit a little higher. So it makes the cente armrest even lower. The higher armrest with the extra storage tray would be perfect. Thank for the tip.Brian
