Is the VIBE supercharger available yet?
NY Pete
Re: Is the VIBE supercharger available yet? (Pablo1669)
Post by NY Pete »
quote:Auto only. Wow. That sux. Wonder why that is. The SC for the Matrix is for both transmissions. I wonder what the difference is? /QUOTE]The difference is that GM cares about the massive wheel hop problem that occurs with the 5 speed manual and the Supercharger, Toyota doesn't (which is why they released the SC for both). GM is currently working on new suspension bushings that will eliminate the wheel hop problems. They are working on it, and it will be released for the Base 5 speed soon enough. Don't go thinking GM doesn't care about their 5-speedersAlso, the reason the GM SC took a little while longer was because they use different ECMs. GM had to make different adjustments to their ECM programs than toyota did.BLEH! I went to Bocherding Pontiac here in Cincinnati and the Parts guy called GM Performance parts to ask why the 5 speed engine code version wasn't showing up. We didn't get any more detail than "not available at this time". Well, if it's not available by the spring, I'll be looking for a Subaru dealer that will take this slow thing on trade for a nice WRX wagon...
'02 Jetta 1.8T Silver Arrow/Black Leathuh - Neuspeed turbo inlet pipe, 17" VW Exor wheels, euro Bora tails, Neuspeed Sofsport Springs, Bilstein HD's, Da'lan hitch'03 20thAE GTI #3494 Imola Yellow/Black Recaros - Omori/AWE boost gauge, HPA Motorsports Short shifter, Neuspeed 28mm rear sway, REVO programming, Neuspeed turbo inlet pipe, FK Badgeless grille, Kamei eyelids and one big fat grin
The Vibe and Matrix are the same engine, trasnmission, and just aobut everything else except for exterior styling and the computer. Why do Toyota and GM need to have different computers? Doesn't the SC come with a new computer module? Seems like you could use the TRD manual trans SC on a vibe. Would probably end the engine warranty though.
Larry
Re: Is the VIBE supercharger available yet? (joatmon)
Post by Larry »
quote:The Vibe and Matrix are the same engine, trasnmission, and just aobut everything else except for exterior styling and the computer. Why do Toyota and GM need to have different computers? Doesn't the SC come with a new computer module? Seems like you could use the TRD manual trans SC on a vibe. Would probably end the engine warranty though.Yes, it comes with a piggy-back unit. I doubt it work with the Vibe becuase it's a different ECU than the Matrix. I'd guess the delay has to do with emissions. It's not easy to take a car, add FI and still have it meet emission standards.
p3vibe
Post by p3vibe »
yes available now in so cal. 12498927 ~$2995
