Automatic or Stick Shift?
DopeVibeGT
Re: Automatic or Stick Shift? (Lori19)
Post by DopeVibeGT »
6 speed all the way!!! My grand am has a 3 speed auto and it loses SO much speed with the auto. I wanted the 180 HP Vibe GT anyway. The 130 HP is a little whimpy for me.
Frosty
Re: Automatic or Stick Shift? (DopeVibeGT)
Post by Frosty »
quote:The 130 HP is a little whimpy for me. See http://forums.genvibe.com/zerothread?id=625 There is only a 1 second difference between the base and the GT to 60 mph. Also it appears that the dyno sez the base 1zz engine is under rated!See http://forums.genvibe.com/zerothread?id=976 Also the Base could have a factory supercharger installed.see http://forums.genvibe.com/zerothread?id=976 So enjoy your GT superiority complex, while you can.Don't look down on a base Vibe
Frosty 5 speed Vibe Power & Safety Packages. Naturally Aspirated my gallery
DopeVibeGT
Re: Automatic or Stick Shift? (Frosty)
I thought the Base vibe only did 0-60 in like 8.8 seconds? Thats more than a second different. And lets not talk 1/4 miles. When you add 50 HP to a vehicle and a manual 6 speed, you will get a much faster vehicle. You took me the wrong way and I have no "GT superiority complex", as you said. Dont label me, please. I've been driving a GA SE for 8 years, and it can smoke many newer GA GT's, so dont judge. I told you what *I* perfer. Whether you take it as an 'attack' on the base is your own interpitation. Sorry you didnt see the little wink at the end. People seems to miss the Emotiocons. And you will be able to get a turbo or S/C on theGT also.Peace.
Frosty
Post by Frosty »
PBFlash
Re: Automatic or Stick Shift? (silverawd26)
Post by PBFlash »
Manual all the way. Besides the performance, it's just more fun to drive.
Satellite Vibe GTMoons and Tunes Package with 6-Disc In Dash CD, Safety/Security/Power Packages, cargo mat. 35% tint all around (except windshield)18 in Motegi Racing MR8 Wheels/Nitto NT 555 225/40ZR-18 tiresStainless Steel Exhaust TipInjen CAIPics of my Vibe CarDomain.com
pmh013
Post by pmh013 »
I wanted a manual, but I demanded AWD. So, priorities rule, and I got an AWD, tagged with the AT. Hopefully they can figure out how to pair the 6 speed with AWD ... that would be sweet!!
Project Shadow
Post by Project Shadow »
quote:6 speed all the way!!! My grand am has a 3 speed auto and it loses SO much speed with the auto. I wanted the 180 HP Vibe GT anyway. The 130 HP is a little whimpy for me. I would like to see just how much faster the GT is 0-60 or 1/4 mile.5 foot pounds of torque seperate these two engines, don't be fooled by 50 HP. HP=torque*RPM GT is rated at a much higher RPM giving the higher HP number but torque and gear ratios are what move you.I realize the GT is faster, but not by much.
Shadow two tone, 5 speed, 16" alloys, power group, ABS safety group, 6CD, 200watt. Love the car.
NovaResource
Re: Automatic or Stick Shift? (Project Shadow)
Post by NovaResource »
quote:5 foot pounds of torque seperate these two engines, don't be fooled by 50 HP. HP=torque*RPM GT is rated at a much higher RPM giving the higher HP number but torque and gear ratios are what move you. I realize the GT is faster, but not by much.It's about .8 sec to a full second faster which is a good amount. Remember, these engines are almost the same to 6400 rpm where the base has to upshift but the GT keeps pulling. When the base shifts, it's gone past it's peak torque while the GT is still climbing to its peak.But don't take my word for it. My car knowledge is merely adequate.
pmh013
Post by pmh013 »
quote:Maybe. Only if there was more horsies and stronger off road capabilities.Well, that's just a given! Who would want to waste 6 gears on 123 HP? That's just silly. I would hope that even GM wouldn't do something that dumb.
Project Shadow
Re: Automatic or Stick Shift? (NovaResource)
I know the GT is faster but I am defending the base with S/C addition plans because it will be much quicker for the same price basically. I have read GT owners knocking that idea of base S/C for weak reasons. Plus .8 sec for $3000.00 more and a decrease in mileage, higher insurance (and four wheel disk)? If I would have seen a 2 sec better time then I wouldn't have been able to resist. Don't get me wrong, I love the high revving GT and don't dissagree with its charms at all but I am not going to agree that the little GT badge makes it SO INSANE compared to the base 5 sp.
NovaResource
quote:I know the GT is faster but I am defending the base with S/C addition plans because it will be much quicker for the same price basically.I agree. Hence the reason for my base Vibe purchase.
DABEAR95
Re: Automatic or Stick Shift? (Admin II)
Post by DABEAR95 »
quote:For anyone that wants to put some kind of forced induction on there vehicle or nitrous also a auto trany will probably work out best for you.With Nitrous has anyone ever seen a vehicle that missed a shift while spraying nitrous? It's not pretty when the engine goes way beyond redline. Your not fast enough to back off the gas before you destroy your engine.A $100 part can solve this problem. It's called a window switch. It turns on the juice at X RPM and turns it off at Y RPM. Say on at 3,000 and off at 8K. So it doesn't matter what you do. However if you go from 3rd to 1st or something odd, it will bend a valve because no rev limited can stop that!---Who ever said torque is what moves you is right, but drag racing is all about HP to weight. Bottom line...(if its geared to use it) HP is the total amount of power put to the ground. Torque is kind of at the moment! Do some research, its interesting.I should know the difference! My golf has 165 ft/lbs at 1900RPM. What does the Vibe have at 1900RPM? The Golf redlines at 4,500 and really stops pulling at 4K...Jason
2003 Vibe GT Lava w/accent + 17'' wheels2002 VW Golf TDI 43City/52Highway lifetime1995 Camaro Z28 CAI,!TB,Airfoil,Shorty Headers,!CAT,Borla exhaust, 3.73's w/eaton posi. 13.5@105 with 245/50/16 Michelin XGT's = no traction
KSNeptune
Post by KSNeptune »
I test drove a six-speed Vibe GT, and hated having to repeatedly reach for the dash mounted lever. It might have been fun when I was 20 to always be shifting gears, but it's not now that I'm 45. I still drive a 5-speed Nissan pickup, and it's gears are such that:1st is for starting out2nd is for anything 15-25mph3rd is for anything 26-394th is for getting to highway speed, and5th is for cruising at 60, 65, 70, 75, or 80.And those ranges meant I shifted very little on any trip I took. But my test drive in the 6-speed had me shifting every half-second, it seemed, just to keep the RPMs high. Yes, I know there is a 5-speed base Vibe, but the shift lever location is still crappy for someone 6'1" who has the seat pushed back. Thus the only version of a Vibe I would buy would end up an automatic. And I love it! It needs more power, but I'll get the supercharger if they ever actually sell one. Otherwise I'll trade the Vibe in on something with a higher power-to-weight ratio.KSNeptune
DABEAR95
Re: Automatic or Stick Shift? (KSNeptune)
Post by DABEAR95 »
Yeah, with the gearing in the GT you do shift alot. High differential, and close ratio in 1st - 4th. Sometimes I find myself going 1st, 3rd, 5th, then 6th when above 47-50MPH.I'm 6 foot flat and don't mind it. Oddly enough, my only automatic is my Camaro!Jason
quote:... the shift lever location is still crappy for someone 6'1" who has the seat pushed back. I'm 6'4" with the seat pushed back, and the shift lever feels like it's right where it ought to be for me. It's also in a good spot to rest your hand on while tweaking the radio. Guess it's what you get used to. Last manual I had was an old 66 Falcon, 3 on the tree with unsync'd 1st. Vibe is a dream compared to that.I test drove both auto and 5 speed, and the auto shifted sooner than I would, which made it feel like it took a lot longer to get up to speed. Then again, I've been caught in some heavy, slow traffic and would have liked the auto then.I hadn't had a manual for a while, and my daily commute is pretty long. Having the manual (and the Vibe in general) makes the commute a lot easier to put up with. Also, because of the long commute, I got the 5 speed for the better gas mileage. Only real gripe on the manual so far is that sometimes it feels like I have to really mash the clutch into the floor to start the engine, but don't trust myself enough to bypass the interlock.
geezer
Post by geezer »
I'm 50 and I've never owned an automatic and don't intend to until I'm either too feeble to push in the clutch or I lose a hand or a leg. The biggest selling point to me for getting the XRS over the XR was the 6-speed vrs the XR's 5-speed. Hell, if some carmaker offered a 7, 8, or 9 speed, I'd probably be lined up to get one -- I love going through the gears.
XRS 6-speed, Cosmic Blue, 17's, AEM Short Ram, Hidden Hitch
Frosty
Re: Automatic or Stick Shift? (joatmon)
Post by Frosty »
quote:... Only real gripe on the manual so far is that sometimes it feels like I have to really mash the clutch into the floor to start the engine, but don't trust myself enough to bypass the interlock.... No need to bypass the interlock.Using the search feature I found...http://forums.genvibe.com/zerothread?id=1533 ....where you will find your fix. Cheers!
Frosty
Re: Automatic or Stick Shift? (geezer)
Post by Frosty »
quote:I'm 50 and I've never owned an automatic and don't intend to until I'm either too feeble to push in the clutch or I lose a hand or a leg. I'll 2nd that at 43 yrs. My dad just recently sold his last daily driver with a manual at 65 yrs old. He still has a 28 model A and a 51 chevy with manuals though.
red
Post by red »
i've driven both over the years and i prefer both dependent of the type of vehicle i am driving. my current is a auto/awd...a stick would have been nice with the small engine but toyo's auto is pretty good for extracting what it can out of the engine....had a fiero gt v-6 with a 5 speed and loved it to death, same with my 4 cylinder renault fuego, not so with my s10 manual (ugh)...my trans am, amx and gto (hurst slaptstick) came with an auto and they were responsive...but one thing i do notice is that when it gets really cold the manuals tend to be less friendlier to shift and you dont dare use your parking brake at -20 below or colder 'cause they can sometimes stick...with my auto, i just slap a pad heater on the tranny pan and its alot easier to operate at these temps...plus anyone can drive an auto vs. a clutch...manuals are becoming a endangered species though which is a shame...they come in handy when you are learning to ride a motorcycle or racing atvs.
From http://www.washingtonpost.com/wp-dyn/ar ... 3Apr9.html , Prince Georges County MD (suburbs of DC) Crime report:MANDAN RD., 7800 block, 8:45 p.m. March 21. A food delivery person was robbed of his wallet and car keys by three males, one armed with a sawed-off shotgun. The robbers attempted to steal the person's vehicle but were unable to operate the manual transmission. The three then fled on foot. No injuries were reported.
rubberman
Post by rubberman »
The wife and I both enjoy driving standards all of our cars have manuals in them.The one thing they should fix is the gearing in the transmission, third gear drops off to much same with fourth fith gear is alright but it still geared more for fuel milage then performance(120kph and under 3000rpm) this makes the car a dog unless you drop a gear.The motor (base) has power but the tranny could make it more useful(better final drive) like my 91 Si
Car&Bike Pics http://www.cardomain.com/ride/2355922/1New Kumho712(summer225/50/16)195/65/15 Dunlops(winter)03 Vibe 49,000kms gone!!!!!New Battery/window rubber pass doorTwo seats fixed(coming apart at the seams)Transmission?,Tires that sound like mudders on a truck(Contis) 18,000kms done/noisey A/C Compreser/poor paintRadio(no am)2 days old ,door speaker replaced
PhantomII
Post by PhantomII »
I also prefer the manual and the shift location is fine for the most part. My two gripes are the terrible box-o-rocks feeling with the sloppy feel. Also depending upon what you have plugged in to 12V or 110V outlet, plugs can get in the way.
If you think cars are fun,Strap on a pair of J-79's sometime Deron LewisVolunteer Crew ChiefF-4C Phantom IIMinnesota Air National Guard MuseumBase Vibe, Moon and Tunes, Satellite
goodvibe
Re: Automatic or Stick Shift? (PhantomII)
Post by goodvibe »
I've had an auto or 2 over the years and they're just not for me. I wouldn't mind a crisp shifting auto that had some engine braking on a car that had more power than it needs and easy manual gear selection. I might even like it more than a manual but all Vibes are not in this catagory and rev matching when downshifting is not really possible, abrubt and hard on the auto. Autos can be great in a straight line when you've got enough juice to spin your tires with the gas peddle but you'll get there faster with a stick in any Vibe. If I needed an auto(only had 1 car for me and the wife) I'ld buy a base SC. We also have an Accord v6. I think people that say they wanted a GT but didn't buy it because of the stick are better off without it. It's not the same car with an auto and was a bad combo in the SRX and celica GTS. I love my 2zz 6sp and I drive 70 mi a day into Chicago traffic.
TrojanGT
Post by TrojanGT »
From http://www.washingtonpost.com/....html , Prince Georges County MD (suburbs of DC) Crime report:MANDAN RD., 7800 block, 8:45 p.m. March 21. A food delivery person was robbed of his wallet and car keys by three males, one armed with a sawed-off shotgun. The robbers attempted to steal the person's vehicle but were unable to operate the manual transmission. The three then fled on foot. No injuries were reported.--------------------------------ROFLOL!I love stick, and one of the arguments my mother and aunt couldn't beat was just this - there's a huge hunk of moron criminals out there who are just too dumb to drive stick, therefore my car is safer from theft! Since our GT is often driven in a larger urban locale, this argument holds up to Mom really well.Not that my Mom dictates my adult choice of a car (not giving my age but we have a now-13 year old kid), but Mom still gives us her two-cents regardless. Thankfully, we haven't faced a test of this theory (knock on wood)Mahalo (and still laughing)Dawn
Re: Automatic or Stick Shift? (TrojanGT)
The only risk you face owning a stick is sure, maybe the criminals won't be able to drive, but wwhat if they try real hard and end up destroying the clutch!!!Could go either way.But I agree, if someone's walking along, looking for a car to steal, I'd put money on it they're less likely to touch a stick than an auto...
Herb
Post by Herb »
I have to say that I'm very happy in general with my GT and the manual transmission that comes with it, however I recently came accross a very inconvienent situation.Last Friday I hurt my back so bad I couldn't move, much less drive. Trying to find a co-worker who supposed to 'know' how to drive standard was difficult, and when I found one he stalled it 4 times, burned the clutch 3 times and shifted into the wrong gear several times.If it wasn't for all the pain and the morphine I had I would have insisted on trading places with him.
MJN2
Post by MJN2 »
My vibe is my 6th car. 2 have been autos and they both required transmission rebuilds within their warranty periods.Nothing but manuals for me nowadays.
Two-tone Neptune GT w/17" OEM rims, Nav System, BOMZ short ram, Sabresport STB
Roadpig
Re: (MJN2)
Post by Roadpig »
Stick, even though my wife can't drive it I told her that I would be more than willing to teach her how to drive it...so the ball is her court.Her big fear is stalling the car on a hill. Not much I can do about that.
2004 Vibe GT, Neptune Two ToneGraphite Interior, Moon & TunesPower Package, 17" Rims, Exhaust Tip Mods Tinted (50% front window, 35% back & rear)Cosmo Alpha Omega 3 Child Seat & Booster SeatCustom Cargo Mat, DebadgedMagnaflow Cat-back Exhaust, Injen CAI
champcaracing
Post by champcaracing »
stick baby, if you've got the gt go stick. nothing like reving it up slamming the gears and HITTING lift!!!!
goodvibe
Re: (champcaracing)
Post by goodvibe »
Stick for me. I generally don't care for the way you can't stop an auto from downshifting when you floor it or having to wait for it to downshift when exitting a slow corner. In more powerful cars with low end torque that don't need as much throttle, a good auto doesn't get in the way. I even find my wifes auto V6 Accord ok but I much prefer driving my Vibe. CVT trannies look to do the best of everything if someone ever gets it right, though I'm sure the engine sound would take some getting used to.
kcinmi
Post by kcinmi »
I had to give in for " Harmony." My Wife will NOT even learn how to drive manual. This is the third car Ive had to give in on, and it will be the last!!!!
God, grant me the serenity to accept the things I can not change,the courage to change the things I can, and the wisdom to know the difference.
Reynoma
Re: Automatic or Stick Shift? (kcinmi)
Post by Reynoma »
Quote, originally posted by kcinmi »I had to give in for " Harmony." My Wife will NOT even learn how to drive manual. This is the third car Ive had to give in on, and it will be the last!!!!I guess I have it pretty good. It was my wife who taught me how to drive a stick in the first place.
Philippians 2:11
AKLGT
Post by AKLGT »
manual tranny was a REQUIREMENT!!! autos are for wimps!
AKLGT1998 Subaru 2.5RS
GMJAP
Re: (trdvibe)
Post by GMJAP »
Quote, originally posted by trdvibe »manual tranny was a REQUIREMENT!!! autos are for wimps! Hear hear!!That's why I wound up with a Vibe - no Matrix was in existence with manual & the options I wanted. (Which turned out to be a good thing - rather have the Vibe now anyway!). And though there was a vibe in existence, I had to get it from Illinois!Better mileage and better performance - what a deal!
ToolGuy
Re: (silverawd26)
Post by ToolGuy »
Auto for daily drivers, manual for my fun cars!Sports cars should be manuals, everything less is a sissy sports car!
fjf511
Post by fjf511 »
Automatic where I live you would shifting all the time your either up the hills or down the hills
04 ABYSS AWDM & TPOWER PACKAGEWINDOW TINT
AzFusionGT
Re: Automatic or Stick Shift? (Herb)
Post by AzFusionGT »
5-speed all the way! My first car was an auto, but every car after that has been manual trans. When I bought my Saturn, I had to order it as the dealer only had automatics. (Does anybody want a stick anymore???)When I test drove my GT, I LOVED it. My Brother is a mechanic, and he had a hard time with it. "Too many damn gears." he said. That's okay 'cause nobody asks to borrow my car.I will drive a 5/6 speed until my knee gives out - then get it replaced and drive some more.
2006 Saturn Vue Red Line -A Moose is on the Loose-1990 Toyota Camry LE-V6 - Katy the Camry -
rAERRK
Post by rAERRK »
6spd or bust
clwcrw
Post by clwcrw »
Stick shift, most definitely!!!I have owned plenty of both. My first real car was a stick. My wife could not drive a stick shift vehicle when we first met. Her father tried to teach her several times, but he would get frustrated with her, so she never really got the handle of it. When we met, I had an '83 S-10 Reg cab, short bed, 4X4, with a 2.8 carburated, 4 speed. It took me one night to teach her. We actually traded in her 2001 Venture mini-van for her Vibe. During the test drive, she said several times that she missed having a manual shift vehicle!Chris Lansing, MI
Currently:'03 Vibe GT'94 9C1 Caprice, stock'01 Suzuki GSXR 600, full system hindle pipe w/Ti can, PC III, K&NNo longer with me:'02 Cavalier LS Sport, 5 speed, ecotec, '97 Grand Prix GTP'94 Camaro Z-28, 6 speed, '98 Suzuki TL1000R
technomobile
Post by technomobile »
lol would LOVE stick, but my feet are too big, hit brake and clutch at same time
tecton
Re: Automatic or Stick Shift? (technomobile)
Post by tecton »
yeah...wellpersonally autos leave me with more time to concentrate on drivingall you have to do is just massage the auto...downshift when you need some power bla bla bla...its not that big of a deal0-30 1st30-70 2nd70-100 3rd100+ OverDrivebut then again, if i didnt get an AWD i would have gotten the XRS....so...cant say much.All the auto needs is a higher stall torque converter, or a transbrake, and a shift kit, thats all
theangrydwarf1
Post by theangrydwarf1 »
Stick all the way! I bought my GT and the ex didnt know how to use it so, it was and still is all mine!
"Do not worry about your difficulties in Mathematics. I can assure you mine are still greater." AE"Science without religion is lame. Religion without science is blind." AE"Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." AE
BlueCrush
Re: Automatic or Stick Shift? (theangrydwarf1)
Post by BlueCrush »
Silly Rabbit! Sticks are for kids!I wanted the AWD!
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
B18B
Re: Automatic or Stick Shift? (BlueCrush)
Post by B18B »
Gotta go with the manual tranny in this car!! Not only does the Automatic SAP power out of the overtaxed 4 banger, but its ratio's are ridiculously high and highway acceleration is tepid at best.I will admit, the autobox in the car is pretty smooth and more convenient in traffic...
tnpartsguy
Post by tnpartsguy »
I'm lazy, so I got the Auto, plus I wanted AWD, and you can't get it with a hogleg.
Psychobroker
Post by Psychobroker »
Quote, originally posted by theangrydwarf1 »Stick all the way! I bought my GT and the ex didnt know how to use it so, it was and still is all mine! Exactly!
21Rouge
Re: Automatic or Stick Shift? (tecton)
Post by 21Rouge »
Quote, originally posted by tecton »personally autos leave me with more time to concentrate on drivingI do enjoy using a 5 speed but my wife does complain when I use the cell while simultaneously upshifting from a stop
cknight725
Re: Automatic or Stick Shift? (Boxgrover)
Post by cknight725 »
Drove them both .. honestly didn't like the hydraulically assisted clutch ... I'm used to old detroit big iron muscle cars with mechanically actuated clutches and the wierd hydraulic feel was not comfy.Went with Auto, more because I couldn't get the options I wanted in short order with a manual car.Now, the 6sp manual in the 04-05 GTO -- NOW THAT IS A TRANSMISSION!!!
---------------------Chris KnightAlbuquerque, NM2005 Base Vibe Auto, M&T, 6-DiscDynomax custom exhaust, XM RoadyII, Cosmo SR Intake, Custom Engine Cover
AZViking
Post by AZViking »
Test drove an 03 GT last year, 5spd, but wasn't ready to buy at the time. Found my 03 Base Auto last week and signed up. The 5spd was nice, but either way was fine with me. My wife's first car was a manual, so it didn't matter to her, but she didn't want to sit in traffic riding the clutch pedal here in PHX.
2015 Kia Sorento 32,000 miles, 2010 Kia Sportage LX, 68,000 miles
goodvibe
Re: Automatic or Stick Shift? (AZViking)
Post by goodvibe »
Either you drove a 5 spd base or 6 spd GT. That's the only way they come. 04-05 GTO like most everything = hydraulic clutch.
