Question about bluebatmobiles overlays
rAERRK
Re: (ColonelPanic)
Post by rAERRK »
Quote, originally posted by ColonelPanic »Mine were a PITA to get installed. Get a spray bottle and put a bit of dish soap in there, fill with water.Clean the light sufficiently. I can't remember what I used, that was a long time ago. Spray the light down with the dish soap/water and you will be able to align the overlay as needed. Turn on the fogs to get the heat necessary to make the material adhere to the surface if you don't have a heat gun. Smooth out with a lint free cloth or something or other...At any rate, they came off my car a lot better than they went on. IF you can get a hold of him see if he will send you another set, customer service wise, that is the right thing to do, even though you messed up and even if it was your fault, I think you should get a free set. At least that's what I would do if I had sold you them.I got the tail overlays, not foglights.He already sent me 2 kits, first one got lost in the mail. I don't see what good another kit would do anyway if I can't get them on.
Re: (rAERRK)
Oh, well never mind then.
scherry2
Re: (rAERRK)
Post by scherry2 »
Quote, originally posted by rAERRK »Just posting to say I got the overlays and couldn't get the stupid things on.why not? what's the problem? mine went on easy I used a spray bottle of soapy water and a heat gun.
djpositivek
Re: (rAERRK)
Post by djpositivek »
did he send instructions and if so, did you follow them ?
Abyss 2005 FWD 5 speedDe-badged
rAERRK
Re: (scherry2)
Post by rAERRK »
Quote, originally posted by scherry2 »why not? what's the problem? mine went on easy I used a spray bottle of soapy water and a heat gun.I think I got frustrated with it too quickly. I didn't use the blowdryer, but I'm going to play around with it some more and see if that will work.I already ruined one piece, so if I do get it to work I'll probally order another set.
scherry2
Re: (rAERRK)
Post by scherry2 »
lost of soapy water then you can work with it as you blow dry it, you have to take your time as you have curves to conform to.
rAERRK
Re: (scherry2)
Post by rAERRK »
Quote, originally posted by scherry2 »lost of soapy water then you can work with it as you blow dry it, you have to take your time as you have curves to conform to. I got out the blowdryer and played with it some today, and got both pieces on Looks great.
scherry2
Re: (rAERRK)
Post by scherry2 »
rAERRK
Re: Question about bluebatmobiles overlays (merckx56)
Post by rAERRK »
Quote, originally posted by merckx56 »http://www.lamin-x.comI have the yellow on my fogs. It's thick, inexpensive and doesn't look cobbled together like those stupid plastic covers...Got any night pics?
