Bad Vibe Partouts, doors, side and hatch glass rear bumper, ecus, 1zz intake mani, 1zz turbo, ps tail and more! LI NY
Bad Vibe
Re: Bad Vibe Full Partout, Doors, bumpers, c60 trans, More L
Post by Bad Vibe »
I have a C60 from a celica modified to fit a corolla, matrix, vibe or spyder shifter
my trans works fine but has slight grinds mostly when cold but doesn't pop out just doesn't like to be rushed
you still need 1 or 2x parts from monkey wrench racing for the shifter conversion shaft and the reverse blockout if you fancy not going into reverse at 30 mph
basically the spyder shifts from the front of the shift shaft and has a 2 bolt bracket for the shifter arm to the right
the celica trans shifts from the rear and the shaft has to be knocked out and the hole in the back needs to be closed off with a freeze out plug (which i did)
the advantage is that the celica shift cable brackets bolt to the same spot as the spyder shifter arm (on the corolla vibe and matrix there is a blank undrilled boss on this spot, on my spyder swap i used a vibe trans and drilled and tapped these two holes)
aside from a spare stock shifter you could maybe cut shorter and a 6 speed trd ball knob i sold everything shift related
03 Vibe GT JDM MR-S 1ZZ-FED swapped w/C60 6 speed - Starting Part out! - 230k mi
90 Celica Alltrac Awd Turbo ST205 swap Red - sold... Buy more parts BC I'm Buying her back!
01 MR2 Spyder Vibe 2ZZ-GE w/ Jdm C65 LSD Trans swap -sold
Bad Vibe
Re: Bad Vibe Full Partout Low Mile 1ZZ-FED, c60 LI NY - Upda
Post by Bad Vibe »
SLP Hood, and Voltz Badge sold
Front and Rear Bumpers, several doors, rear hatch inner panel would be lovely to be rid of as they are quite large
making a scrap run with the rest of the chassis and a lot of random large plastics any one need a piece cut out speak now or forever hold your piece
klutzycarlover
Re: Bad Vibe Full Partouts, doors, bumpers, c60 and more! LI
Post by klutzycarlover »
You didn't scrap it yet, did you? Also, I want those headlights, front bumper, and rear roof rack cap(p/s) if you have it.
I lost my roof rack hardware, do you have any of it by chance?
I might have a use for that c60. Mine sounds like it's about to go, I don't think it will like 300hp much. I'm hoping I can make it last until the e154f goes in,
but that is unlikely.
Bad Vibe
Post by Bad Vibe »
I did scrap chassis, front subframe, hubs, p/s rack
saved rear beam, sway bars, heater box, pretty much everything that unbolted
I do have the foggy headlights, decent front bumper, the grumpy grindy c60, and all roof rack hardware besides crossbars
Bad Vibe
Re: Bad Vibe Full Partouts, doors, bumpers and more! LI NY
Post by Bad Vibe »
the grindtastic c60 miraculously sold to a guy swapping a 2zz into an aw11 Mr2 pretty noble cause for it
ramenboy...
Post by ramenboy... »
my fan was not blowing at low, so for the last 2 years was running at medium. this morning, no fan except for high.
do you have a blower resistor?
o4 pontiac vibe
thanx in advance
de-badged o4 vibe
o2 triumph speed four
Bad Vibe
Post by Bad Vibe »
i should let me confirm, ship or pickup?
ramenboy...
ship! 'm in the chicagoland area :|
edit 2 december: i didn't realize the resistor was so inexpensive. i ended up picking one up at the local parts store here. all set
de-badged o4 vibe
Bad Vibe
Post by Bad Vibe »
bump for pending bumper sale
still have several doors mirrors switches small bits, rear beam, lower control arms full poly bushings set
msu90
Post by msu90 »
Any chance you have a windshield fluid pump (shipped to Michigan)? TIA
Reysie
Post by Reysie »
Do you have passenger side cladding for 2003 Vibe? If do, how much?
Bad Vibe
Post by Bad Vibe »
i have a lot of cladding unpainted, blue or black and the whole side or one door?
Reysie
Post by Reysie »
It will be the whole passenger side in black; how much and shipping charges to Rochester, NY 14622. Thanks
Reysie
Post by Reysie »
Don't need the doors.
Bad Vibe
Post by Bad Vibe »
OK I sorted through my trim, I do have a complete p/s in black
I have pending sale on d/s blue and p/s black front door cladding
I have an additional p/s front door cladding in black
Also black:
2x p/s rear door
1x p/s rear qtr
2x d/s rear qtr (1x in unpainted grey)
1x d/s front fender (scuffed w/ one broken clip)
1xp/s front fender
And also 1x d/s+p/s front fender cladding in unpainted grey
https://docs.google.com/file/d/0B_sios5 ... cslist_api" onclick="window.open(this.href);return false;
Also have several interior plastic pillar trims as well as the rear cargo floor and seat backs
Reysie
Post by Reysie »
Thank you for your quick response, but these pieces I have; I need the bottom section where the rocker is, all across the bottom. :( about that, not making myself clear. I hope you have that. Thank you again.
Bad Vibe
Post by Bad Vibe »
i have a few side skirts left but gonna have to pull them down not sure if i have a black one still
Bad Vibe
Post by Bad Vibe »
msu90 wrote:Any chance you have a windshield fluid pump (shipped to Michigan)? TIA
didnt see your post i should I will let you know
klutzycarlover
Bad Vibe wrote:I did scrap chassis, front subframe, hubs, p/s rack
Sorry it took so long for me to reply... I didn't have it set to send me email updates. :roll:
I could use the roof rack bolts soon. And also the rear caps. Get me a price shipped to 89052 if you still have em.
dannyy72
Post by dannyy72 »
Long shot in the dark. I read previous posts that you have a upper and lower spoiler for sale? Can you send me pics?
Bad Vibe
Post by Bad Vibe »
Mid spoiler sold, upper spoiler is black and still wrapped up but I'll go check it out of you're interested
dannyy72
Post by dannyy72 »
Yes interested. Can you send some pictures?
ppaschka
Post by ppaschka »
Do you still have the battery hold down clamp by chance? How much would you like for it?
2003 Base Vibe w/ Manual Transmission
Bad Vibe
Post by Bad Vibe »
I should still have it, i'll take a look while I'm playing paparazzi with my disrobed spoiler tonight
ppaschka
Post by ppaschka »
OK, I found out I need a new rear wiper motor as well. Do you have that? Thanks!
Bad Vibe
Post by Bad Vibe »
That I definitely have, sorry for making everyone wait on pics my parts are in detached garage beyond a muddy field of melting snow and a not hard to get to and school work gym keeps getting in way off Thurs will get back to everyone then
Bad Vibe
Post by Bad Vibe »
Rear spoiler black is good,
Rear wiper motor with or without arm is good
P/s mirror is no good only have drivers side painted blue left
Also have rear glass w/tint and black painted top part w/ washer sprayer
Also took pics of
Pair of
Foggy headlights
Front calipers
2 Good p/s tail lights ( and one d/s with a Spyder crack)
Also washer bottle
Dash bezel
05+ upper grills
Bad Vibe
Post by Bad Vibe »
Fogs sold, here's pics - also while im sure i have a battery tie down i have no idea where it may be and could not find it after 1/2 hr of digging so....
ghetto looking but functional radio
abs unit
Is the metal part of the hatch glass plain black or metallic black?
Bad Vibe
Post by Bad Vibe »
Painted Black metalic
ppaschka
Post by ppaschka »
How much do you want for the rear wiper motor? (I don't need the arm.) If you find the battery clamp, great; if not, not a problem.
Bad Vibe
Post by Bad Vibe »
pm'd
Bad Vibe
Post by Bad Vibe »
Fogs sold, Wiper motor and spoiler ready to be shipped if you guys are still interested
vegetony
Post by vegetony »
Did you say you had side skirts? I have a 2004 Vibe base and wanted to see if I could put those on. The part number may be part of the
12498773 Sport Package
Bad Vibe
Post by Bad Vibe »
no sport package parts besides spoiler just basic grey side skirts
vegetony
Post by vegetony »
Thanks, sent a pm.
Reysie
Post by Reysie »
Do you still have that black rear spoiler and does it fit a 2003 vibe? I'm interested if it does and thanks for checking on the skirts, I have all those that you have, I need the bottom one, one whole piece that runs at the bottom passenger side.
Bad Vibe
Post by Bad Vibe »
Still have spoiler and basic 03 side skirts unpainted
CatManDu
Post by CatManDu »
Do you still have the radio bezel w/ switches? How Much?
I live in Oregon.
rickiann
Post by rickiann »
Would you have a driver side
rear tail light assembly that fits 2005 base vibe? How much?
rickiannitelli@hotmail.com
Bad Vibe
Post by Bad Vibe »
I have the one pictured above with the crack in it, still usable Ps I have a good one
Reysie
Post by Reysie »
When you say basic side skirt are you referring to the lower one? Can you post a picture, I'm interested in the spoiler and the skirt, how much and shipping charges for 14622 zip.
Bad Vibe
Post by Bad Vibe »
any one buying this spoiler?
Salsa Guy
Post by Salsa Guy »
TRD Shiftknob? How much shipped to 74019
jcharles00
Post by jcharles00 »
is the leather console box still around?
Bad Vibe
Post by Bad Vibe »
pretty sure i sold it ill double check tho
biodieselrabbit
Post by biodieselrabbit »
Did you sell the driver's side rear tail light/blinker assembly? You mentioned that you have a cracked one (picture shown) but also maybe a good one? Can you send me a private message if you still have them with costs to ship to 97202? Thanks.
2003 Pontiac Vibe
What did you want for the spoiler and headlight assemblies?
msu90
Post by msu90 »
Would you happen to have the antenna mast and base?
o2ej
Post by o2ej »
is there a cooling fan motor available for 2006 base? cost?
