Post
by BlueCrush » Thu Sep 18, 2008 5:26 am
They blew a transformer...uh oh! We're all gonna die!!!! AAAAAAAAHHHHHHHHHHHH!Quote »Transformer breaks on world's largest atom smasher, forcing suspension at European facilityBy ALEXANDER G. HIGGINS , Associated PressLast update: September 18, 2008 - 3:14 PMGENEVA - A 30-ton transformer that cools the world's largest particle collider malfunctioned, forcing physicists to stop using the atom smasher just a day after launching it to great fanfare, the European Organization for Nuclear Research said Thursday.The faulty transformer has been replaced and the ring in the 17-mile circular tunnel under the Swiss-French border has been cooled back down to near zero on the Kelvin scale — minus 459.67 degrees Fahrenheit — the most efficient operating temperature, said a statement by CERN, as the organization is known.When the transformer malfunctioned, operating temperatures rose from below 2 Kelvin to 4.5 Kelvin — extraordinarily cold by most standards, but warmer than the normal operating temperature.CERN had not reported any problems with the project since its launch Sept. 10, but issued its statement shortly after The Associated Press called asking about rumors of troubles.The Large Hadron Collider is designed to collide protons in the beams so that they shatter and reveal more about the makeup of matter and the universe.After it was started up Sept. 10, scientists circled a beam of protons in a clockwise direction at the speed of light. They shut that down, then turned on a counterclockwise beam."Several hundred orbits" were made, CERN's statement said.On the evening of Sept. 11, scientists had succeeded in controlling the counterclockwise beam with equipment that keeps the protons in the tightly bunched stream that will be needed for collisions, but then the transformer failed and the system was shut down, the statement said.The clockwise beam was not on at the time. Now that the transformer has been replaced and the equipment rechilled, scientists expect to try soon to tighten the clockwise beam and prepare experiments in coming weeks, the statement said.Before the problem occurred, scientists had said it would probably be several weeks before the first significant collisions were attempted.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
