Delco Radio Pin Diagram
gragon
Post by gragon »
Delco radio pin outs for those who need it.
cohocarl
Re: Delco Radio Pin Diagram (gragon)
Post by cohocarl »
Thank you very much for posting that. Some of us are curious if the cd changer terminals will accept line level input from like a DVD or mp3 player, or if it is a different type of signal. Do you have any idea?Thanks,Carl
Jahntassa
Re: Delco Radio Pin Diagram (cohocarl)
Post by Jahntassa »
If you saw the XM Satellite Radio thread, I have a unit from P.I.E. that will interface.I'm installing it tomorrow, and will post a seperate thread on it. It plugs into the 12 pin on the back of the headunit..to the PIE unit, then to the changer. It will accept three line-ins and has a seperate switch to change between them and the changer.
gragon
Post by gragon »
A fellow posted this on the Matrix Owners board and I figured you guys would need it also.
johnsoax
Post by johnsoax »
quote:Delco radio pin outs for those who need it.Thats interesting because my Delphi drawing shows generally the same with a few differences.A1 - Class 2A2 - Class 2A3 - SW_PWRA4 - FM_DET+A5 - GNDA6 - ASWC_REF_OUTA7 - RUI1A8 - LF+A9 - LF-A10 - RR-A11 - RR+A12 - GNDB1 - BattB2 - IGNB3 - ANTSPLYB4 - DIM+B5 - DIM-B6 - AMP_SENSEB7 - RUI2B8 - LR+B9 - LR-B10 - RF-B11 - RF+B12 - PARKM - AUX_MON+L - AUX_MON-K - AUX_COMJ - LAUXINH - RAUXING - CLASS2A - CEL_TEL_MUTEB - Not used (Test Point)C - GNDD - GNDE - Not Used (Test Point)F - Not Used (Test Point)
Re: Delco Radio Pin Diagram (johnsoax)
Could one diagram be the M&T radio, and the other just the base radio?
johnsoax
Re: Delco Radio Pin Diagram (ragingfish)
Post by johnsoax »
Could be, mine is for the in-dash 6-disk M&T radio.
NovaResource
Post by NovaResource »
quote:Could one diagram be the M&T radio, and the other just the base radio?There is no "M&T Radio". The M&T package is available with the base single-disc radio or the upgrade 6-disc in-dash radio.
johnsoax
Re: Delco Radio Pin Diagram (NovaResource)
Post by johnsoax »
Didn't know that, thanks for the info.
quote:There is no "M&T Radio". The M&T package is available with the base single-disc radio or the upgrade 6-disc in-dash radio.Ah. Is it the amp that changes then?
NovaResource
quote:Ah. Is it the amp that changes then?Basically. The "Tunes" part of the "Moon & Tunes" package is an added amp under the passenger seat and the addition of 2 tweeter speakers on the front door A-pillars.
Gotcha.
NovaResource
The reason the M&T package is not available with the Nav system is because the Nav system has a 6-disc remote CD changer under the passenger seat where the amp usually goes. There is no room for the changer and the amp. Because you can't split out the moonroof from the M&T package (at least in the US) this is why you can't get a moonroof with the Nav system.
Ah. Good to know!
cohocarl
Post by cohocarl »
quote:The "Toons" part of the "Moon & Toons" package..."Toons"??? As in Cartoons? Pontoons? I thought it was "Tunes". Get your head out of your amp Nova.
NovaResource
I hate brain fade. Thanks for catching that. I corrected my stupidity.
quote:I hate brain fade. Thanks for catching that. I corrected my stupidity.LOL! I thought you intentionally did that.
