VibeBear wrote:sorry for the wait! I've been working late & haven't had time to check. Pulled apart the dash after work today. it was the red wire I moved.... still in the bottom row, but moved to the spot to the right of the green wire. I've included a pic of it.
Thank you for this post. I have a 2010 Pontiac Vibe with standard Audio system plus onstar. Used the Scosche GM18B. Moved the red wire to the bottom row to the right of the green wire. It was very easy, if you do it right. Use a small, flat screwdriver to pop open the black plastic latch that give access to the pins. Press very lightly on the little silver clip that holds the pin and pull the wire. Don't press to hard like I did, you'll have to dig the latch back out with a very small tool. Just pop it into the now position and you're good to go. I dd not use the blue remote wire, solid orange wire, or black wire. I directly attached the black wire from the radio to the chassis ground bolt in the lower right of the dash opening. Also needed an adapter forte non-standard antenna pin.
Don't use on-star, so I can't comment on that, though I'm sure it doesn't work. Everything else, including antenna and dimming, works. Let me know if you have questions and I'll try to answer them.
