P0741=Torque Converter Clutch Circuit Performance or Stuck Off
Postby aspuccini » Mon Sep 22, 2008 3:03 pm
My check engine light came on for the first time, 91,150 miles. I got the code read at autozone it said P0741- Torque Converter Clutch Circuit Performance or Stuck Off. I haven't had any performance issues. No shifting problems etc. I reset light came on 20 min. later. Does anybody have an idea?
aspuccini
Re: P0741=Torque Converter Clutch Circuit Performance or Stuck Off (aspuccini)
Postby impalamike3800 » Tue Sep 23, 2008 10:24 am
any modifications done to the vehicle? how hard do you drive it?
I AM THE 3800 ROCKSTAR!http://www.cardomain.com/ride/2191849
impalamike3800
Re: P0741=Torque Converter Clutch Circuit Performance or Stuck Off (impalamike3800)
Postby aspuccini » Tue Sep 23, 2008 3:43 pm
No modifications. Don't drive too hard. Daily Driver. I have not had any problems, hear nothing from the engine or tranny, shifts fine RPM good, good gas mileage etc.. Could it be a sensor that is bad? Or the Solenoid it self? I know I hit a large bump...I mean it jerked me hard, about 1/2 mile before the initial CEL.
aspuccini
Postby impalamike3800 » Wed Sep 24, 2008 2:40 am
you may have jarred something loose under there. take a look at the trans solinoid and see if the plug is completly on.
impalamike3800
Postby aspuccini » Wed Sep 24, 2008 9:03 am
Thanks man that is what is was. I actually spent the $25 and went to an transmission shop to have them tell me this. He said he has only rebuilt one vibe auto transmission. They rarely have problems etc.
aspuccini
Postby impalamike3800 » Wed Sep 24, 2008 11:43 am
glad to hear. now toss in a high stall and some gears ;-)
impalamike3800
Re: (impalamike3800)
Postby vivacelife » Sat Oct 18, 2008 2:22 am
I have the same problem too! I don't know what caused it but I drove over a huge pothole the other day and took my car to a new place to get the oil change. About a day after that, the "check" light came on on my dashboard (I drive an '05 Corolla). Nothing seems to be malfunctioning other than the light.
I took my car to Pepboys and spent 20 bucks to get the code. The code came back to be the same problem: TCC circuit performance or stuck off. They reset my light and so far it's not on.
Do I need to let someone look at my car? Is it a serious problem? What do you think the problem may be?
vivacelife
Re: (vivacelife)
Postby blue_can » Sun Oct 19, 2008 11:53 am
What it means is that the ECM cannot detect a return current from the TCC solenoid. If that's the case the TCC may not be engaging when it should. You probably won't notice the problem other than worse gas mileage.
It may be simply that the connector has come loose - check the wiring to the transmission. Worst case the TCC solenoid has become faulty - it should be a straightforward repair (altough I think on the A246E you have to drop the valve body to access the solenoids - that may make it more expensive). Do the simple things first like cleaning out the connector contacts etc.
blue_can
Re: (blue_can)
Postby blue_can » Mon Oct 20, 2008 12:55 pm
Sorry I was mistaken - since this is a performance code and not an electrical code it just means that the ECM could not detect a TCC lock condition not using the return current method. However, the reason are similar although it could be that the TCC is jammed inside the torque converter so the repair could potentially be more expensive.
blue_can
Re: (blue_can)
Postby tribalman » Mon Dec 07, 2009 4:27 am
this is my 3rd? time getting this code. first time was a long time ago, at least a year. i just cleared it and checked to see if it came up again, it didn't. about 2 weeks ago i was driving on an off ramp and there is a bump, got the code. a few days later the light went off(not 100% sure this was the same code as i couldn't find my reader). then last night i hit the same bump and the code came back on. looks like it is related to the car hitting a big bump violently. i'm going to check to see if something is loose. any other ideas on how to keep the code from popping up again?
Current mods:
stereo, 4-way speakers, 500 watt amp, 12" sub.
custom cargo cover.
DRL/Fog/Automatic light mod now out here! http://forums.genvibe.com/zerothread?id=38372
tribalman
Postby atm711 » Thu Oct 14, 2010 11:02 pm
i'm going through that exact same problem i drive a 96 cadillac deville i've been driving the car with my check engine light on for some time now and it won't pass inspection cause of that one code TCC but it pass it last year when i went to the same place where i got inspected
atm711
Re: (blue_can)
Postby gmstarks » Wed Dec 29, 2010 5:32 am
I have a 1998 Cadillac Deville 4.6L (which I bought at an auction, because I can not afford to buy a new car-with...car payments). Advance Auto did a diagnosis' and found the following codes: PO113, PO420, PO741. Could someone please tell me about how much each one of these items should cost me to be repaired. I have looked up the codes and have a brief description for each one, But, being a lay woman and unfamiliar with the pricing for each job, I don't want a mechanic to cheat me out of the little bit of money that I do have. Thanks for all your help.
G
gmstarks
Re: (gmstarks)
Postby keithvibe » Wed Dec 29, 2010 6:08 am
you would be better off asking here
http://www.cadillacforums.com/
Cadilacs are too expensive to repair, which is why we all have pontiac vibe's
2010 Vibe & member of the year
garage
Email me if you need to talk to me, click my siggy and send the email threw the contact page.
keithvibe
Re: (keithvibe)
Postby gmstarks » Thu Dec 30, 2010 1:04 am
Thanks for your help.
G
gmstarks
Return to Engine & Transmission
Who is online
Users browsing this forum: Google [Bot] and 0 guests
x
