wiring diagram
katepwa
wiring diagram
Post by katepwa »
Does someone know what each colour wire is for for the stock stereoOr where I can get the info for free Thanks
tcam
Re: wiring diagram (katepwa)
Post by tcam »
Hey Daryl, and welcome to genvibe!Unfortunately I am electrically challenged too. At least when it comes to that type of wiring. But I hear that it's not too complicated once you learn the basics.sry that i can't give u any help, but I know others on here will be able to.
GMJAP
Post by GMJAP »
Try this for wiring harness connector:
katepwa
Re: wiring diagram (GMJAP)
Post by katepwa »
Thanks for the wiring Diagrams they helpNow if i can only figure out why my SOUNDGATE AUXGMV3 auxillary input adaptor will not work when I wire it in.I am using the AUX button for the switch but there is not dang audio, when I plug a mp3 or my XM into itThe instructions that came with the Soundagte device suck I am using the cd/radio without the cd changer.. Anyone else using one of those >?
GMJAP
Post by GMJAP »
Quote, originally posted by katepwa »Thanks for the wiring Diagrams they helpNow if i can only figure out why my SOUNDGATE AUXGMV3 auxillary input adaptor will not work when I wire it in.I am using the AUX button for the switch but there is not dang audio, when I plug a mp3 or my XM into itThe instructions that came with the Soundagte device suck I am using the cd/radio without the cd changer.. Anyone else using one of those >?From what I gather by briefly poking around online, it seems to use the XM input, not the CD changer one. Try using the BAND button to select XM1 & see if you get audio.
