Possible trouble with hatch button on my remote
Sub-Vibe-R
Post by Sub-Vibe-R »
I got my Vibe yesterday and I tried to use the hach button on the remote and nothing happend. I tested both remote and nothing happend on both. Lock/unlock works fine but I'm wondering if it is normal the hach button does not do anything.
NSimkins
Global Moderator
Re: Possible trouble with hatch button on my remote (Sub-Vibe-R)
Post by NSimkins »
You have to hold the HATCH button down for about 2-3 seconds before it unlocks.If that doesn't work, see the dealer.
Sub-Vibe-R
Re: Possible trouble with hatch button on my remote (NSimkins)
I'll try that and keept you updated. I press hach button for about 1 sec. Another question about that. Is the hach button open the tail gate or only the rear window?
NSimkins
Global Moderator
Post by NSimkins »
quote:Another question about that. Is the hach button open the tail gate or only the rear window? It only opens the rear hatch glass window, not the entire hatch itself. Also note, the glass hatch doesn't pop fully open when you use the HATCH button on the remote, it just unlocks the window so you can pull it open yourself.The UNLOCK button on your remote (pressed twice) will unlock the main hatch.
Sub-Vibe-R
Thanks NSimkins. I'll try that as soon I'll be back home. If it does not work, I will advise my dealer at my next appointement for oil chage.Are the light flashing when we push the hatch button? Mine are not.They only flash one for lock and twice for unlock.
NSimkins
Global Moderator
Post by NSimkins »
quote:Are the light flashing when we push the hatch button? Mine are not.They only flash one for lock and twice for unlock.No, the lights do not flash with the HATCH button. Only, as you said, with LOCK and UNLOCK.
NovaResource
Post by NovaResource »
You know, if you actually read the owners manual, you would know this already.KEY FOB These only work when teh key is NOT in the ignition. Press UNLOCK once = unlocks drivers door only (lights flash twice) Press UNLOCK twice = unlocks all doors and rear hatch door but not the hatch glass (lights flash twice) Press and hold HATCH for about 2-3 seconds = pops hatch glass (no lights flash) Press LOCK = locks all doors and rear hatch door but not the glass (lights flash once) This only works if all doors are hatch glass are closedDOOR SWITCH Press UNLOCK = unlocks all doors and rear hatch door but not rear hatch glass (no lights flash) Press LOCK = locks all doors and rear hatch door but not rear hatch glass (no lights flash) This only works if the key is NOT in the ignition. Pressing LOCK on the door switch with the key in the ignition will UNLOCK all doors.MISCELLANEOUS Press the HATCH button on the dash = pops hatch glass (no lights flash) Insert key in rear hatch and turn counter-clockwise unlocks the hatch door Insert key in rear hatch and turn clockwise to position one locks the hatch door only Insert key in rear hatch and turn clockwise past position 1 to position 2 unlocks the hatch glass The only way to lock the hatch glass is to close it by hand.Also for cars with power locks: Insert key in driver door and turn once unlocks driver door only, turn key a second time and it unlocks all doors and the rear hatch door (not the glass). Insert key in passenger door and turn once unlocks all doors and the rear hatch door (not the glass).READ THE MANUAL!
Frosty
Re: Possible trouble with hatch button on my remote (NovaResource)
Post by Frosty »
quote:You know, if you actually read the owners manual, you would know this already. READ THE MANUAL! AMEN. Here is a link to the U.S. online manual for those who missed it. Bookmark it (or save the pdf file) for your convenience. http://www.mygmlink.com/pdf/go2content/ ... 03vibe.pdf note to self: Is there a Canadian pdf out there?
Frosty 5 speed Vibe Power & Safety Packages. Naturally Aspirated my gallery
LavaTroll
Re: Possible trouble with hatch button on my remote (Frosty)
Post by LavaTroll »
I actually did read the manual (with usual lightning speed, molasses comprehension) and missed this item. I thought my hatch button didn't work, either. It's probably for the best that you have to hold it down really deliberately.
Lava 5-speed manual with Moon & Tunes playing surf, reggae, hardcore, metal, British Invasion and my original music
Sputnik
Post by Sputnik »
quote:READ THE MANUAL! Or do a search on Genvibe!
GenVibe Global Moderator
NovaResource
Re: Possible trouble with hatch button on my remote (LavaTroll)
LavaTroll, does it work now that you know the correct procedure? I ask because some people on this board did have problems with the rear hatch unlocking. However, I think most were with the door and not the glass.
baltimore17
Post by baltimore17 »
OK, I spent 2 hours at the dealer's reading the manual the evening I ordered the Vibe back in August. And I downloaded the online version and read it. And I read the whole "how it all works" from Scott (thank you very much for the most concise description thus far) posted above. And, in three weeks or so, I hope to be able to experiment with my own, real, live Vibe. But I still don't see a way to drive up to the grocery loading lane, with the key in the ignition, with the engine running, and remotely pop the whole hatch, sheet metal and all. Do I have to stop the engine, remove the key, and use the fob?
vibb
Re: Possible trouble with hatch button on my remote (baltimore17)
Post by vibb »
quote: But I still don't see a way to drive up to the grocery loading lane, with the key in the ignition, with the engine running, and remotely pop the whole hatch, sheet metal and all. As Scott wrote "Press UNLOCK twice = unlocks all doors and rear hatch door but not the hatch glass (lights flash twice)"If only your driver door is unlocked and you are sitting inside the car, just hit the unlock button on your driver's door panel.So, if you are driving around with all 4 doors unlocked this includes the hatch door. So you can leave the engine running, and just open the hatch, or someone from outside can open it and climb in!
Ex-Vibe owner
Sub-Vibe-R
Re: Possible trouble with hatch button on my remote (vibb)
Yesterday, when I came back form work, I tried to hold the hatch button and what a surprise, the hatch pops up!I won`t have to go to the service dept. to have it fixed. quote: READ THE MANUAL! Yes NovaRessource, your wrigh. We should read the manual before using someting.I read it, but no very carefully and I missed that point. Moral of this story: Read the owner manual before saying there`s problem or it does not work. Very often, it is a user problem.
esjones
Post by esjones »
I think a key point here is to understand the difference between UNLOCKED and OPEN.OPENing the full hatch is ALWAYS done by hand. You only LOCK and UNLOCK it using the keys, fobs, door switch, etc.Hope this helps.Earl(Vibe ordered 11/7)
- Earl Earl Jones, Sales and MarketingHorizon Systems LLChttp://www.horizonsystems.com/ Skype ID: esjonesMy Vibe: '03 Base, 5-speed, ABS, Alum. Wheels, Power Pkg, DVD Nav., Security, Neptune/Graphite
NovaResource
quote:But I still don't see a way to drive up to the grocery loading lane, with the key in the ignition, with the engine running, and remotely pop the whole hatch, sheet metal and all.The fob does not work if the key is in the ignition (engine running or not). If you want to pop the rear hatch (not glass) just press the unlock button on the door panel. That unlocks all the doors and rear hatch. If you just want to pop the rear glass, press the button on the dash to the left of the steering wheel.
NovaResource
quote:Moral of this story: Read the owner manual before saying there`s problem or it does not work. Very often, it is a user problem.Don't feel bad, that's a common problem where I work.I call them ID-10-T errors. I'll say "You have an ID10T on your computer."Sometime we call them PEBCAK errors: Problem Exists Between Chair And Keyboard
Sub-Vibe-R
quote:Don't feel bad, that's a common problem where I work.I call them ID-10-T errors. I'll say "You have an ID10T on your computer."Sometime we call them PEBCAK errors: Problem Exists Between Chair And KeyboardI work at ATT Canada, voice repair centre. I get often trouble like that. Usualy, we call that a finger trouble or a 18" (average distance between the chair and the computer).
Kent
Post by Kent »
quote:Don't feel bad, that's a common problem where I work.I call them ID-10-T errors. I'll say "You have an ID10T on your computer."Sometime we call them PEBCAK errors: Problem Exists Between Chair And KeyboardI work at ATT Canada, voice repair centre. I get often trouble like that. Usualy, we call that a finger trouble or a 18" (average distance between the chair and the computer).Sounds like what we call a "Carbon Unit Failure".K
2003 Satellite Vibe - Power Package - Alloy Wheels Cargo Nets - All Weather Mats - Cargo Mat - Backseat Storage
baltimore17
quote: If you want to pop the rear hatch (not glass) just press the unlock button on the door panel. That unlocks all the doors and rear hatch. So simple! I kept looking in the manual for a separate button (as on my older cars). Regarding the collision between the masses and technology, one of the digital system architects I used to work with often said "it's hard to make a device foolproof because fools are so darned ingenious".
