Garmin GPS unique install
Posted: Mon Sep 13, 2004 8:06 am
by cspmeinkc
This was an easy install. Any Garmin 3, 3plus, or 5 will fit perfectly!I just took the door out and drilled holes in the rear so the 2 wires can be routed. One wire is for the power, the other is for the external antenna. You can get a "bnc" type external antenna at gilsson.com for around 20 bucks. You can have a navigation system in your car for less than 300 bucks! Another great part is the door will shut when not in use.
Re: Garmin GPS unique install (cspmeinkc)
Posted: Tue Sep 14, 2004 3:20 am
by ebslopp
Isn't it hard to see it while your driving?
Re: Garmin GPS unique install (Salsa!)
Posted: Tue Sep 14, 2004 4:23 am
by cspmeinkc
the screen is lit bright. I can if i want to, pull the unit out (with wires still attached) and put it on my dash to see as well.If i input way points, it beeps at me to tell me when to look at it for instructions on were to go. It usually takes only a quick glance.If anyone has any other ideas were to mount it out of sight, please tell me. I thought about mounting it on the silver trim part around the radio, but then i would have to move it every time i left the car.........
